Question about Weber Q Grill
How to remove burner tube on a webber q - Weber Q Grill
2 Suggested Answers
  • 4 Answers
SOURCE: Ignition problem on 2nd and 3rd tube
You may have to take them out and blow the burners out with an air compressor. It is very hard to tell if they are stopped up internally.
Posted on Jun 05, 2009
Webber Spirit 2 burner front burner light right away, back burner lights after a couple minutes. What should I do?
check and clean spark electrode on back burners and check burners are not blocked
Jun 07, 2018 | Grilling
I have an older Webber gas grill. It either cooks at very high heat or very low heat. There is no in between. What could be the problem?
A faulty control valve is the only reason for that. What happens when you observe the flames at the burner as you turn the control? Small flame to large flame? One other thing you can check is the venturi tube, that is the part just after the knob and jet, and just before the burner. Often they get filled with spider nests.
Apr 21, 2018 | Grilling
I want to remove the tube burners on the Gennise 1000 model,I can,t locate a diagram showing the proper way to remove and reinstall the tube burner. I must have a spider or insect nest in the tube and I...
On the majority of weber grills, the tube burners fit over the valve and the back of the burner fits into slots in the back of the fire box. The proper way to remove and repalce the burners is to remove the front panel whilch will allow the valves to move forward so the burners can move forward and out of the slots in the back of the fire box. To put the new burners in, you simply reverse the process. Once caution. be sure that you get the new burners properly seated over the vavles or you will have a flash back fire behind the front panel and damage the vavles and igniters.
Jun 27, 2011 | Weber-Stephen Products Spirit E-310 Gas...
How do you remove the venturi tubes of a Blue Ember Gas Grill? The manual explains how to clean the venturi tubes, but it doesn't say how to remove the tubes for cleaning. The manual just says...
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
Apr 18, 2011 | Fiesta Blue Ember Gas Grill
I have a Webber Q Family BBQ for about 2 - 3years. I noticed say last 6 months that the burners are not working properly and the grill is not hot enough ie take 3 times longer to cook a steak etc. I read...
OK, it sounds to me that when you changed the propane tank, you may have turned the gas tank valve on too fast. Doing so causes the built-in excess flow valve to check, which only allows a trickle of gas through. Do this: Turn off the gas tank, disconnect it and drain any remaining gas from the grill by opening a valve to a burner. Close the grill valve and then reconnect the tank. Very slowly open the tank valve and try lighting a burner again and see it that solves the problem. Douglas
Sep 12, 2010 | Ovens
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
Jun 04, 2009 | Weber Genesis Silver B Grill
Replacement of gas burners
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find a parts listing with the parts numbers at: http://www.charbroil.com/Parts/80/Performance-Series.aspx
If this was helpful, please vote yes. Thank You!!
May 29, 2009 | Char-Broil Advantage 463453306
RIGHT KNOB MELTED .WHY
Hi, Sorry but nobody wants to give bad news. There is a tube that comes from the control knob to the orifice that controls the amount of gas to the burners, my guess without being able to look at it is that the orifice broke at the connection to the tube and the flames are shooting back toward the knob. However it is possible that the venturi opening ( the screened part on the burner tube that sets on the orifice ) became dislodged. Either way you need to remove the grate, remove the burner assembly and then look ( under the cart from the back) at the tube and orifice for damage. You do not indicate how old any of this is and they do rust out. Parts are available but you have to determine if based on age and damage you want to replace any of it or all of it. If you inspect it and find something that you think you can fix you can get back to us for more help. If it is as simple as the dislodged tube and the parts are OK, reseat it and check it out. I wish you the best of Luck!
Feb 05, 2009 | Char-Broil 463220004 Grill
Weber Q Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
