Question about Kyocera Mita FS-C5020N Led Printer
Fs-c5020n does not pass the power-on self-test. After one hour it still shows self test and it doesn't do anything.
  • LP Tec
    LP Tec Apr 14, 2014
    If I keep a cover open, it passes self test and ask to close this cover but after that, again SELF TEST message and does anything.
    Problem Solver:
  • 43 Answers
May be bad cover interlock switch
Posted on May 30, 2014
3 Suggested Answers
n25an
  • 622 Answers
SOURCE: Receieve ?Call Service? referencing the # F030:0014903 on Kyocera
main controller board is bad
Posted on Dec 24, 2009
n25an
  • 622 Answers
SOURCE: FS-C5020N just put new toner in, color not print
your best bet with this one.. is to call kyocera support... they might give you a simple answer.. where as a tech will charge you an arm and a leg...
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Black streaks on my output on printer fs-c5020n
chec below things
1. clean the drum unit
2. check the charge unit also
3. clean inside of the printer ...
4. check fuser unit heat roller any black streak is there...........
Nov 07, 2009 | Laser FS-C5020N Led Printer
Can not print pdf double-sided on Kyocera FS C5020N
surprised you actually got doublesided... ok... in a situation like yours... I would update to the latest adobe reader... that has been known to give you issues with printing.... and if it continues call kyocera support... this sounds like an issue they would want to work on...
Oct 05, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Apr 23, 2009 | Kyocera Mita FS-C5020N Led Printer
Laptop help
yes, may be the hard drive... so goahead and run a test on hard drive....
try going to bios setup.... from the main menu in bios... highlight the hard drive... maybe displayed in first drive, or second drive...push Enter... and from the list select an option smart self test...
There would be two test's one is smart self test and smart extented self test... first select the smart self test... it would go up to 5 min... if it is pass go to second test...ie., smart extended test...it would go upto an hour.
If first test fails... no need to run the second...directly replace the hdd... but if pass go to second.. and check the hard drive..
As you said you are using UBUNTU.... try install it again.. if hdd both test pass..
Aug 21, 2008 | Computers & Internet
KYOCERA FS C5020N PRINTER QUEUE
remove from driver from control pannal>add remove program>
uninstall your printer driver & reinstall it i m shore its help u
Feb 21, 2008 | HP PSC 1410v All-in-One Printer
Kyocera Mita FS-C5020N Led Printer Logo
87 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
