Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
Machine Stopped working. lights come on but grinder doesn't start
Any ideas? Lights blink. There's power. But machine won't start.
Suggestion:
Make sure there is no capsule trapped in the machine.
Unplug the unit and with for about a minute.
Plug it in again.
Same problem again: repeat process, but reset the dosing (see the manual - I believe it is done by holding buttons down on start-up, or something similar)
You may have simply put the machine in a kind of learning mode, in order to alter the dosing setting which has a default.
Posted on Apr 14, 2014
Hi my breville barista express does not grind the beans, and the "single/double" light is blinking, what is the problem?
My wife tried to make my coffee and long story short, she removed the lid to "move the beans around"..The grinder stopped working and the filter size lights began flashing intermittently. After taking the whole thing apart, the only REAL problem is that the lock mechanism inside the hopper came unlocked. So put your machine back together and "lock" the hopper. The lights will stop flashing...lets hope
Sep 26, 2013 | Breville Die Cast 800ESXL Espresso Machine
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
Grind Off light blinking
Mine was doing that for the past week. I think it was indicating there had been a power outage but that the clock had not reset to zeros. I changed the time a couple of minutes and it stopped.
Sep 24, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
Lights flash alternating between red lights and green lights
The EEprom (memory of the machine) has crash. Needs to be re-programmed or substituted.
May 18, 2009 | Krups Orchestro 889 Espresso Machine
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
253 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
