Hotpoint wmf740 It keeps saying door and clicking but won't do a cycle
    Champion:
  • 226 Answers
When the door closes, it latches to a micro switch, remove the panel at the top of unit usually only 2 to 4 screws. make sure you unplug the unit, look from the top were the latch lock is located, see if the micro switch is out of place, it has a small button on the switch that gets pushed when you close the door, you may be avail to move , adjust or bent the mechanism to make it work, if not , 2 thing you can do, replace it, it is only 2 screws or by pass the switch, no recommended. but it works. to by pass the switch, connect both terminal wires toghether and tape them for safety or short. unit works, that is your problem. good luck.
Posted on Apr 14, 2014
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Hotpoint washer wmf740. I start the cycle and instead of the drum filling up it came gushing out from either underneath or from the back..flooding the kitchen. What's wrong?
bad hose somewhere? either corroded or came loose from a connection? remove cabinet fill with water then look to see where leak is coming from.
Feb 06, 2015 | Hotpoint Washing Machines
HI! I HAVE A MESSAGE ON MY HOTPOINT WMF760P WASHING MACHINE OF ' DOOR ' COMING UP & IT'S STOPPING SHORT OF THE WASH CYCLE & THEN YOU CAN HEAR THE LOCK MECHANISM
http://www.ebay.co.uk/itm/HOTPOINT-WMD9692-WMF520-WMF540-WMF560-WMF720-WMF740-DOOR-INTERLOCK-SWITCH-/390558604486?pt=UK_Irons_Presses&hash=item5aef1b5cc6
you need one of these
take the lid off and open the door
isolate the mains supply and water supply
remove the two screws that secure the interlock
this is what the doors catch sits in
reach down and tilt slide it out
remove the plug
plug in the new one
and remount
screw back in the two screws hand tight avoid stripping the plastic
and return the lid in position
now reconnect the water and mains and test
the door closes and the machine should now work aok
did one the other day
Dec 08, 2014 | Hotpoint Washing Machines
Hotpoint wmf740
YOUR PROGRAMME DIAL HAS THREADED SO YOU WILL NEED A NEW ONE, YOU CAN GOOGLE THE PART FOR AN EXACT PRICE
Dec 29, 2013 | Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
The machine won't start as saying door isn't
1.the door may be worn at the point it presses the switch at 2.the door switch may be wired incorrectly 3.the door switch may be worn out and needs to be replaced
Mar 06, 2010 | Washing Machines
Hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Nov 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
