Zasounussi problems sour smell in washing machine
    Champion:
  • 226 Answers
On all front loaders, the smell comes from not been used every day, #1, and water sit at the bottom of the drum, is always water in the system from the top of the drain hose to the pump, and they, the manufacture recommend that you use some chemical once per month to clean the unit.
this is what I do. get a bucket of water and bleach 3 water 1 part bleach, get a rug that you do not need any more. wet the rug and with your hand open the door and put the rug unter the rubber around the glass door, in other worth's, the rubber that connects the door to the drum bucket rinclos and water and other material stays there, building mildew, would be good to wear a globe, and clean the inside of these rubber real nice, go around several times to make sure you don't miss a spot., the cloth well come out black means it is loaded. then put the rest of the water and bleach in the machine, add 2 caps of bleach in the machine, fill it to hi and let it stay for 1 hour or more in the drum, then have a gentle cycle, these well clean the rest of the unit. one more thing, if you have members of the family that forget coins or papers in they pocket. may have to do more work to clean and drain the unit, just let me know I well help you.
Posted on Apr 14, 2014
Coldcut
  • 1554 Answers
SOURCE: Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Posted on Feb 14, 2008
  • 1028 Answers
SOURCE: KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Posted on Sep 13, 2008
shadtremonky
  • 353 Answers
SOURCE: my clothes smell sour after washing?
run a load whit nothing but water ,detergent, and two cups of bleach
Posted on Jun 27, 2009
57 varieties
  • 1653 Answers
SOURCE: sour smell inside washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
  • 784 Answers
SOURCE: My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
Posted on Oct 05, 2009
I cleaned my washer with affresh and it still smells very sour
dump a box a baking soda in it and run empty . see if it helps your problem
Jun 22, 2016 | Whirlpool WTW6400SW Cabrio Washer
Sour smell in kenmore elite top loader
Try putting a cup of amonia in with your detergent,when you wash.
Jul 23, 2012 | Kenmore Elite 20972
Clothes have a sour smell to them after being washed; what is the problem?
my mom always told me that after you use the washing machine, you have to keep the door open. otherwise, mold and mildew will flourish, and it will get on your clothes when you wash them.
Jul 22, 2012 | Whirlpool Washing Machines
Kenmore Calypso washing machine has an odor during washing cycle
clean the washer with bleach and a small amount of detergent
Apr 20, 2010 | Washing Machines
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
How do I get the sour smell out of the washer. I
I found a 50/50 solution of vinegar and warm water will generally do the trick.
Nov 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Oct 05, 2009 | GE WHRE5260E Top Load Washer
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Sour smell on towel after washing them
That is comon with LG.
Clean out the filter in the front.
Than take an OLD towel.
Wash with chlorox first a hot load. After that do the same but than with vinegar and that should take care of the SOUR problem
I have an LG too.
Jun 19, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
