Question about Ariens Garden
I have an Ariens self propel mower model # 911016.I think it runs hot. It sounds to me like it is racing?
So I know this sounds crazy but when I pull back the mower it runs fast. I can only slow it down by having it run in heavy grass.
    Problem Solver:
  • 14 Answers
Should be a cable connected to the handle, might be reversed or could of been snagged causing it to give you this issue
Posted on Apr 14, 2014
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
SOURCE: Troy Built 6.75 Self Propelled to Slow
You have to take off a part behind the gears and move it to a slot farther away. Mine was the same way. It's in the manual on how to adjust the speed to go faster.
Posted on May 30, 2009
dnewcombe1
  • 1564 Answers
SOURCE: troy bilt self propelled problem
My only guess is you've put the cable actuator in upside down. Sorry, that's the only thing that makes any sense.
Posted on Aug 14, 2009
  • 61 Answers
SOURCE: adjustment for self propell speed?
no adjustment for drive
Posted on Apr 29, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Lawn mower sounds like it is running fast and vibrating.
Sounds like a bent shaft, or bent blade.
Also sounds like the part that holds the blade to the shaft is sheared, and allowing the motor to run faster than it would if it is turning the blade properly.
Hope this helped,
Please rate me
Posted on May 26, 2010
Testimonial: "Your response was very helpful. Is there a repair manual or instructions online that I could get to describe the process to repair the mower? Again thanks for your response. "
How do I replace the rubber friction ring on a ariens self propelled mower
you should have a dealer do it. because it will need to be adjust to the new friction ring. or you'll wear out the new one prematurely
May 27, 2016 | Ariens Garden
How can I get a airfilter for a Ariens model 911077
Generally you can get away with a different brand that shares the component. Just take in the old one to compare when you purchase. They need to be the same size.
Jul 19, 2014 | Filter Queen Defender Air Purifier
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Hope this helped,
Please rate me
May 25, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Mower will start but when I pull back on the self propelled handle it doesn't take off, you have to push it still. The self propelled cable has came loose from down under the plastic piece that covers the...
Im a girl and I fixed it myself, yay! The cable had broke down where the self propel is at and came out of the eye that it was to be in so i re-wired ti back. Anyways Im glad I didn't get a response on here cause I got a bad steer about my tv and i think you just are guessing and hope people don't bother any longer and that you have lucky guessed. thanks anyways
Jun 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
97 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
