Question about Hoover Vacuums
Panasonic unblock the hose suction if fine but not picking up properly when just using the vacuum itself
Clean out the hose that connects the beater bar to the rest of the hose you have it clogged these kinds of problems can easily be seen DU
Posted on Apr 14, 2014
SOURCE: Loss of suction when vacuuming
I had the same problem, but it wasn't a belt. Instead, it was the input hole under the roller that was jammed up with lint and other stuff.
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: Loss of suction in my Hoover Windtunnel bagless selfpropelled upright
There's also the possibility that the fan/impeller has stripped loose from the motor shaft and is basically sitting there while the motor turns. Also, you may have broken vanes on the fan/impeller that will drastically reduce the suction. Replacement fans aren't very expensive to replace if it's stripped or broken.
Posted on Mar 13, 2008
SOURCE: bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
Posted on Jun 15, 2008
  • 4 Answers
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Posted on Jul 10, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
Mar 12, 2014 | Riccar Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Not efficiently picking up anything, suction seems to be low
In my experience, you have a clog somewhere between the floor and the bag or what ever catches the dirt. Push something through all hoses. Look at all filters. Try running the machine (outside) while it is open to check the vaccum power.
Sep 07, 2009 | Panasonic MC-V7398 Upright Vacuum
No suction
there are two reasons for this 1 is the belt in good order 2 thevac is blocked unblock then trouble free
Aug 12, 2009 | Hoover U6630-900 WindTunnel Bagless...
Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
May 13, 2009 | Vacuums
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
No suction in the hose
Take the Hose out bcack run the water hose thru it full blast to unclog it then leave it hanging to dirty all the water left inside out.
Aug 20, 2008 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
