Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Hard drive recorder
Locked up
  • Official Brand Answer
  • 350 Answers
Remove the unit's power cord and hold the POWER button while plugging the power cord back in. This will unlock most recorders.
Posted on Apr 14, 2014
How do I transfer recorded movies to a external hard drive?
That depends. What device did you use to record these movies? If you recorded a movie using a DVD recorder, connect your external hard drive to a PC device which has a DVD rom. Go into the files, copy and past the file to your external drive.
Sep 15, 2016 | Hard Computers & Internet
Panasonic DVD Recorder
well does not work quite in that way. First there is a reset procedure , I will try to find out which is the reset procedure for your device
Mar 16, 2008 | Panasonic DMR-E80H DVD Recorder
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
I was using my recorder and it locked up. Nothing worked, I couldn't get any of the track arming buttons, transport buttons, the shutdown button, or the mute/solo buttons to work. the only thing that...
It sounds like the hard drive has failed... cheap test, get another and reformat the new one. They are so inexpensive now. To avoid losing data, they lock things up if anything goes wrong. The unit probably can't get the ready signal from the drive and freezes...
Apr 21, 2011 | Tascam 2488mkii 24 Track Recording...
How can I lock my simple tech hard drive from other users
there are many softwares that you can use. Tryb the following link. it's very user friendly.
http://www.newsoftwares.net/folderlock/
Mar 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
Locked up. Hard drive frozen?
i have the same frickin problem.someone please help
Dec 29, 2007 | Fostex MR16HD/CD Digital Recorder
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
stephnt:
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Nov 16, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Recording
The EDSR1600 will not go into manual recording mode (by pressing the REC button on the front panel) unless all of the automatic modes are disabled and the hard drive bays are firmly pressed in and locked. Press the MENU button, select ALARM and turn everything in the OPeration column to OFF. Return to the MENU, select MOTION and also turn set all the OPerations to OFF. Return again to the main MENU and under RECORD, set ALARM RECORD OPERATION to OFF, PRE-ALARM RECORD OPERATION to OFF, and PERMANENT RECORD OPERATION to OFF. Note: Turn the JOG wheel clockwise or counter-clockwise to select an option. Press the ENTER button to confirm the option and move to the next field. Press the MENU button to enter, or return to the main MENU. Press the MENU button twice to exit the main MENU. To check if the round key locks on the front of the Hard Drive bay trays are locked, turn OFF the EDSR1600. Open (pull down) the left side front cover and gently pull up on the drive bay handles. If locked, the handles should not lift and the bays should not slide out. After your check, press the bays in firmly to ensure good seating of the Hard Drives. The ESDR1600 should now go into manual RECord if the DVR is working properly. The red REC LED should also light each time a recording is being made. If the REC LED flashes, this means the DVR is recording a field or frame of video.
Jan 26, 2007 | EverFocus EDSR1600 16 CHANNEL 160GB...
Problem recording
Jan 26, 2007 | EverFocus EDSR1600/500
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
