Question about EPoX EP-3VWB+ Motherboard
Acquisto I need this type of card where I can buy it
    Renaissance:
    An user who is expert in 3 categories / brands.
  • EPoX Master
  • 2,226 Answers
The motherboard you can get at abay
Posted on Apr 14, 2014
I have money but how i can buy the memory card
take the camera to a camera store or an electronics store and ask them for a memory card to suit camera.
or
get model number and google model number and specs
then note type of memory card that it can take .
google this type of memory card to buy online.
Dec 17, 2016 | Cameras
Do I need to buy a memory card for it and if so what type?
Refer to UG on card type. Of course you are to buy one if the internal card (usually for 10-20 photos) doesn't give you enough memory.
Apr 14, 2015 | Video Cameras
I need to buy a Multiscreen Card Colorgraphic Predator Type LT 4PCI 612304
It is going to be hard to replace the exact graphics card due to its age. Your best bet is to replace it with another graphics card that is compatible with your motherboard. The good news is many cards should be compatible with your board since there are very few connection types available.
Post which motherboard you have or simply do a search for what type of graphics card type/connection it accepts. I believe it will be a PCI or PCI Express type card. To make it easiest on yourself make sure the new card you buy has the type of monitor cables you would like to use.
There are really only 3 types it could use and most likely it will use a VGA (blue smallish cable that only accepts pins) and/or DVI (White longer connection with a square and pins).
Hope that helps.
Apr 16, 2014 | Color Graphics PREDATOR LT4, (16 MB)...
Identify correct network card for dell xps 420
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Nov 29, 2012 | Dell Ethernet Card Network Adapter
What type of Memory card should I buy for my sanyo VPC-s120 this is my first camera and I cant find out what type of card I need.
It uses SD and SDHC cards, ranging up to 32GB in size. You don't need to worry about the brand or the speed.
Feb 14, 2011 | Sanyo VPC-S120 Digital Camera
How can I find out what type of motherboard?
Don't worry about it, most motherboard supports expansion devices and most common device that can fit into slots are PCI devices. Buy a Windows 7 ready PCI sound card and place it in one of the slots of your motherboard.
Thanks for using Fixya.
Jul 27, 2010 | Dell Optiplex GX280 (99301) Motherboard
Need graphic card agp slot?
an agp slot card is the older type the newer one is pci express.
if you are buying a graphics card make sure you dont buy the newer pci express if you board only supports the agp type
May 06, 2009 | Intel Celeron D 355, 3.33 GHz...
How do i install a better graphics card
Start by Identifying what type of Card you need to buy. The Manual would be Extremely helpful in identifying What type of Video card slot you have. If that option is out you can look in the device manager and that should tell you what type.
There are many types For any modern Cards your Hoping for an AGP or PCIe Slot bare minimum you need a pci slot.
If you have a Vesa or ISA slot you'd be better off spending money on a new Motherboard & CPU
Once you know what type of card to buy PCI, AGP, or PCIe go out and look for the best card that fits your budget and that your PC meets its requirements
Most new Vid cards require a power supply connection or sometimes two or a special power supply adapter in addition to the available card slot PCIe comes in different speeds x1 x8 an x16 Make sure you have the right one that your card needs before buying. AGP likewise comes in 2 varieties AGP and AGP2 they have a different pin count on their edge connector so make sure what connector it has. PCI just about every semi modern PC has at least 2 PCI slots question is are the currently filled with other cards
Once you've purchased your card, you need to determine if you have an integrated video card.
This would be a video connection that is built into your motherboard.
If you do then you need to look up how to enter your BIOS to disable it (Usually pressing<Delete> or <F12> during boot up. Then go through and change the on board video card to disabled
press <F10> to save and exit
power down PC
Unplug power cord
Remove case cover and install new Video card
Replace case cover and plug back in
Boot up PC
Get Operating system up
insert the CD that came with the new card to install drivers and utilities (Another alternative is to go to the website for the GPU or card manufacturer and get the latest drivers) [ often times the drivers on the install disc are already outdated]
reboot ....... Congratulations your need Vid Card is install Now go play that game your dying to beat ;)
Hope this helps
Dave
Nov 07, 2008 | Gateway Computers & Internet
Finepix a330
What type of xD card did you buy?  It needs to be a plain xD card with no letters before the file size or a type "M" card.  For type "M" you will need to upgrade the camera's firmware.
http://www.fujifilm.com/products/digital/download/a330/fupd.html
This type of camera can't use type "H" cards, so cards like "H512mb" aren't going to work.
To initialize a card choose Menu. Arrow over to "Set", then arrow up to choose "Set-up". On screen "1" of the Set-up, arrow down to choose "Format".
This will ask you to erase all the images from the card, and format it.
Just today I upgraded my camera firmware to accept a type "M" card, initialized the type "M" card after that - and now it's working fine!
Reply back if you need more help. -Kelly.
Nov 21, 2007 | Fuji FinePix A330 Digital Camera
EPoX EP-3VWB+ Motherboard Logo
24 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
