Question about Saeco Odea Giro Plus Coffee Maker
No response from the machine when turned on!
No response, no lights, absolutely nothing, have checked the power point and there is power to the machine?
Machine is behaving as if not getting any power, but light is on. Press foot pedal and absolutely nothing happens
There is probably a bad connection in your foot pedal. Try moving it around with your hands at the contact points while pressing to activate. If it goes when you are shifting its position then it needs to be fixed or replaced.
May 20, 2014 | Janome Sewing Machines
The power button lights up but absolutely nothing else works..NOTHING!...had machine for 8 months..these are too expensive to be disposable..help?...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
We came home from a weekend vacation and the TV won't turn on at all. there are no lights, no response from the remote, nothing. It worked fine on Friday and now Sunday, it is shot. I thought possibly...
Hi, Check that the plug has power. Use a light to do this. Also check the TV cord maybe bad.
Check breaker pannel. Make absolute sure that you have power getting to the TV. If all is good you need a repairman. Good luck
Jun 20, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Tried to turn on laptop. Nothing happened. Hooked up power cord. Left for over an hour. Tried to turn on. Nothing. No lights, no sound, absolutely nothing. Purchased for Christmas 2009.
There are a few steps that you can take, sounds like a power issue. However, being that you are just inside your warranty, i would call Acer and see if they can replace it for you. Once this warranty expires you will be responsible for all costs so I would do this while you still have it covered.
Oct 17, 2010 | Acer Aspire 5602WLMI Notebook
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Have a Compaq Notebook V5005US PC that won't turn on. The only light showing on the front is the IDE light. No battery light. Don't know what might have happened? Was working when I turned it off.
Unplug the power cable then remove the battery and let it sit out for a while. Then put it back in and try it. Sometimes the battery can cause issues. not saying this is the absolute fix, but it's a starting point. Post a response if this doesn't help and we can take the next step to try and troubleshoot it.
Jun 19, 2009 | Toshiba Satellite Pro 490CDT Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
Saeco Odea Giro Plus Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
