Question about Saeco Odea Giro Plus Coffee Maker
Machine won't start, have nothing, no lights, nothing, have checked power point so there is power to the unit?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
Try different electrical outlet
Posted on Apr 15, 2014
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Zanussi zsf 6161 dishwasher - won't start program cycle
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Car won't start, no lights, no nothing.
Check battery is fully charged and good connection on terminal`s, check all lead`s and fixing`s are secure finally check all earthing points.. Good-luck....
Dec 31, 2012 | 1995 Toyota Camry
Dead machine nothing lights up
try to replace 2 fuses they or in the female power socket you have to open the cover right next to the power plug in its part of the black plastic unit
Oct 10, 2012 | Lavazza Espresso Point Capsule Machine
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Saeco Odea Giro Plus Coffee Maker Logo
265 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
