Question about Samsung SCX 4200 All-In-One Laser Printer
Paper not picking up, did diagnostics and each sensor show as off, is this right
    Champion:
  • 312 Answers
For the most part, when paper is not being picked up from the tray, the roller is the cause. If you will examine the roller for slick parts, paper dust etc, you will find your culprit real fast. Also check the tray for signs of wear and make sure the paper guides are butted up against the paper.
Posted on Apr 14, 2014
HP DesignJet T790 gives indication clean paper from a way of passing
After all this I hate to ask, are you sure the paper is loaded square on the spindle? I have had some users not seat the paper correctly when loading and that causes issues.
Sep 11, 2016 | HP Designjet T790 Inkjet Large Format...
My Hp officejet k7100 is not picking up paper and sometimes it ll be showing red light,
You have to clean your printer and also need to clean paper picking sensor with clean dry brush.
Aug 24, 2016 | HP OfficeJet K7100 Photo inkJet Printer
When i try to print it takes shows error, what do ido?
That suggests that the problem was not with the feeder or shaft, but with a sensor.
Can you check the sensors, or cal a service agent?
May 26, 2016 | HP LaserJet P2015 Printer
Model 7502. Why doesn't it pick up paper from tray 1?
Probably the default tray has been changed to tray 2.then again if it's that it don't pick at all then check the pick up rollers. Clean with damp cloth
Apr 25, 2016 | Ricoh Office Equipment & Supplies
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
I am having a problem with my hp3210. It picks up paper but then shows jam . How would i know if the paper sensor is working
This is a common problem, Make sure the pick up rollers are clean (damp cloth and rub side to side) they may pick the paper but slip during the pick causing the paper to arrive late at the sensor. Check the fault codes or jam report from the information tab. If there are 13.1 jams, this is a good indication of the dirty roller problem.
Dec 21, 2010 | Office Equipment & Supplies
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Brother printer Drum problem
Several things to check, the P/U roller is warn down, could be the paper sensor or the paper in the tray is set too tight
Feb 12, 2009 | Brother HL 1450 Laser Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
32 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
