Question about Saeco Odea Giro Plus Coffee Maker
Machine won't start, have nothing, no lights, nothing, have checked power point so there is power to the unit?
No response from machine at all, no lights nothing when turned on? There is power to the unit!
5 Suggested Answers
mirran
  • 515 Answers
SOURCE: No Power
Take off the water tank and loosen the two screw in the chassi. Lift the chassis little and take off the back piece.
If your machine is new model then you have a round boiler on the right side, put in a finger between the chassi and the boiler, you have two thermostat fuse you have to reset.
If you have a old model the you have a fuse on a wire, if you not find any wire with fuse, then you have to take off the top of the machine. You will then see the power card, find the fuse on it and check it.
Hope this will help you.
Best regards
/Mirran
Posted on Aug 30, 2008
  • 8 Answers
SOURCE: No power; no response when I push start.
There are thermal breakers located on the boiler.
Push in the little button on the breaker to reset it.
Note: very trickey to get at the breakers.
You need very small hands or you will have to extract the machine out of the housing, which can be trickey.
Watch the dredge drawer switch if extracting.
Posted on Jun 24, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a brand new machine. I am having a similar
Try pressing the brew button while the you prime the machine.
Posted on Nov 29, 2009
SOURCE: The machine itself will not turn on.
sounds like the CPU board is out. This is the brain to the machine...
cost to repair ranges from $80.00 to $180.00-variance is based on how much damage was caused when the board went out...
I have a shop that I send mine to in CA, aLatteHotte-you can check out their website on line. I refuse to giv emine up so repairing is the only option for me. hope this helps
Posted on Dec 03, 2009
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Zanussi zsf 6161 dishwasher - won't start program cycle
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Dead machine nothing lights up
try to replace 2 fuses they or in the female power socket you have to open the cover right next to the power plug in its part of the black plastic unit
Oct 10, 2012 | Lavazza Espresso Point Capsule Machine
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
I have a brand new reliable industrial sewing machine msk-8400bl18. i had a sewing machine guy out that showed us how to use machine, thread etc. about a month ago. everything went smooth and sewing...
hi.
given that the machine is only a month or so old, the best advice i can give you is to do nothing to the machine and call the sewing machine guy out to repair it for you. a brand new machine like this will be covered by the warranty. as long as you have actually switched the machine on properly, any faults are the responsibility of the supplier at this stage.
Jul 26, 2011 | Reliable MSK8400BL25 Mechanical Sewing...
Start your wash machine
If your washer doesn't seem to work at all, check these: No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 01, 2010 | Maytag PAV2300 Top Load Washer
Saeco Odea Giro Plus Coffee Maker Logo
18 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
