Question about Microsoft Windows 7 Professional OEM x64bit DSP
Handheld Visor for Windows 7 - Microsoft Windows 7 Professional OEM x64bit DSP
  • Joe M Jun 16, 2014
    Hi Magnus Auer, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
I have a Handspring Visor Graphite Handheld and when i shnged the bateries i lost all my data. Anyone can help?
If you have hotsynced your Visor with a PC (or Mac), the first time you sync your Visor to that computer, it should restore all the data from the last hotsync to the PDA. This is one big reason that it makes sense to sync your PDA on a regular basis.
Unfortunately, if you never used the hotsync function for your Visor, you may not be able to recover any of your data. This model Handspring Visor requires good batteries or else everything in its memory will randomize and you will lose all stored information. There is a small capacitor in the Visor that provides enough reserve power for about 30-60 seconds when you pull out the batteries. It's for this reason that Palm recommended pulling out only one battery at a time when changing to a fresh set. That minimized the amount of time that the PDA would be without power. That same advice applies equally to Visor PDAs.
Jun 15, 2011 | Handspring Visor Graphite Handheld
Instructions for supertooth visor go model no.btstlgo.
Have lost my instructions for VisorGo CE0678 Model No: BTSTLO
May 29, 2010 | Handspring Visor Prism Handheld
Is the Handspring Visor Delux compatible with Windows Vista?
yes it is compatible with the palm desktop that comes on the disc or the palm desktop 4.14
Apr 09, 2010 | Handspring Visor Deluxe Handheld
Handspring visor pro on Vista
The easiest way to do this is by usb. You will need to download the 6.2 palm desktop/hotsync manager (yes, it says it will not work with your prism... I know.) Then you'll need to download pimlico's palmhotsyncsetup tool, that will allow it to work.
You can read the full instructions and get the appropriate links here:
http://forums.palm.com/t5/Windows-HotSync/Windows-7-and-Vista-hotsync-instructions-here/td-p/251755
Mar 06, 2010 | Handspring Visor Pro Handheld
Can not hot sync my unit with windows vista
Palm says that it is not possible, because the software that they have does not work with Vista. However, there is a fix to this! :) For these instructions, you will need the usb cord. If you need to do it via bluetooth, or infrared (IR) or want to read further instructions, visit this link:
First, you will want to download the Palm desktop 6.2 and hotsync manager here:
http://kb.palm.com/wps/portal/kb/common/article/32859_en.html
Then, you'll need to download the Pimlico hotsync software here:
http://www.pimlicosoftware.com/palmhotsyncsetup.exe
Install them both, and you're off!
~Marianne Is-Loved~
Dec 30, 2009 | Handspring Visor Prism Handheld
I have lost the instructions for my Vodafone BT visor bluetooth
I have the instructions if you would like to give me your e-mail address i will send them to you
Apr 30, 2009 | Handspring Visor Prism Handheld
Old VISOR
Congratulations on your 'first generation' Handspring Visor purchase. While perhaps 'old technology' in the techno world, I am still using mine today. To answer your question, your Visor is simply attempting to 'synch' with your desktop files (to ensure you have the correct data in both places. Your error stems from the fact that the unit is 'searching' for your desktop files to perform that handshake. Like an unanswered telephone; your Visor 'hangs up.' You will need to install the software on your PC. Yes, there is still software out there. ;-)
Nov 29, 2007 | Handspring Visor Prism Handheld
Migrating software and data to new computer
Assume that your Visor is your data respository. So you should make sure that you have an up-to-date synchronization from the NT PC. Now get the XP compatible software for your Visor from the palmOne website and install it on the XP box. I assume that you will be synching via USB this time - this is the default setup when you install the software. Hopefully you still have the USB cradle that came with the Visor. You can still use serial sync with XP but you should try to take advantage of the speed of USB on the new PC. Download for XP & Visors: http://www.palmone.com/us/support/downloads/visor/win_desktop_401.html Once the software is installed, sync with the new computer and all your data should be copied from the Visor to your PC in the first synchronization. By the way, Outlook shouild be installed on the new computer before you install the Visor software; otherwise the installer will not offfer to install the PocketMirror conduits.
Sep 13, 2005 | Handspring Visor Deluxe Handheld
Where do I download a program to hot sync my visor to my desktop?
Palm Desktop for Visors - same as CD software http://www.palmone.com/us/support/downloads/visor/win_desktop_401.html
Sep 12, 2005 | Handspring Visor Deluxe Handheld
Microsoft Windows 7 Professional OEM x64bit DSP Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
