Question about Measuring Tools & Sensors
Replace wheel bearings in greenfield 13hp ride mower
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
wadembly
  • 513 Answers
SOURCE: How to replace lower deck spindle bearing on my
take the deck off or take the belt off of pulley there is a nut on top of pulley loosen nut with a brass hammer hammer it down & it should drop the spindle out to replace bearings
Posted on Jul 09, 2009
  • 257 Answers
SOURCE: Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Posted on Aug 15, 2009
dnewcombe1
  • 1564 Answers
SOURCE: HUSQVARNA-YTH1848XP riding mower with loose front right wheel.
Of course they are. The company sent you the wrong bearings.
Posted on Aug 22, 2009
SOURCE: i am trying to remove the cutter drive pulley from
Hello Mate, I know its been awhile since you posted but the deck pulley has a left hand thread. hope this helps.
Posted on Aug 30, 2010
How do I remove a bearing from the shaft?
cut it with an abrasive cut off tool.
Aug 02, 2016 | Garden
How do I remove the steering wheel from my 13hp cox stockman mower, tried putting upward pressure while hitting shaft with dolly and hammer with no success
There appears to be a roll pin up under the steering wheel that holds it on the shaft. You will have to tap this out with a small punch or nail before you can remove the wheel.
Feb 23, 2015 | Garden
How do I replace rear axle bearing greenfield ride on mower
some transaxles ARE NOT serviceable...
Sep 01, 2014 | Garden
GREENFIELD 8, 11 & 12 HP ANNIVSARY manual
Some manufacturers will not sell the full manual to consumers, perhaps yours will.
Your best bet is to email them with the full model and serial number of your mower with your request:
http://www.greenfield.com.au/contact.html
Jun 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Measuring Tools & Sensors Logo
23 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
