Question about Lexmark E232 Laser Printer
Printer making marks down the left hand side of every page
I have a Lexmark C 532n printer that is about 5 years old. It has never been a problem until now. It has started to make a mark down the left hand side of the page on every print. On the very outside of the left page it is black & blue print with about half an inch gap between the marks. Can you please suggest a fix
  • Dan Broatch Jul 28, 2009
    Spot on.
    Many thanks
  • Lexmark Master
  • 1,684 Answers
This sounds like the photoconductor units for both black and blue need to e replaced. Open the front of the printer like you are changing toner cartridges. On the front door parts that opens to you there will e four pieces, 1 for each color. Look at the one with blue on it and the one with black and look on the ends of these, they are the photoconductor units. I bet both of the colors have worn sections compared tothe magenta and yellow ones. The replacement part number is C53030X and you will need 2 of these. They have a life span just like toner and have to be replaced too.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Testimonial: "Spot on... solved the problem"
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
Lexmark 4039 laser printer is printing left side of the page faint
check the cartridge it has a toner pcr and cylinder inside maybe its defective or the ic chips
Feb 19, 2013 | Lexmark 4039P 4039 Plus Laser Printer...
I am getting blue mark on the left hand side of the page on every page that prints. It is not a solid line down the page. It is ever so often down the left hand side it is a lexmark c543n
You say every so often, does that mean at a similair interval. If you have a repetitive defect, you can measure and that will tell you exactly what is wrong, but in most cases with these printers if it is isolated to a single color it will be either the toner or the drum that is bad.
Apr 25, 2011 | Office Equipment & Supplies
How to change the black ink cartriage
User guide available for free from here
http://www.intel.com/support/chipsets/sb/cs-009236.htm
Go to page 69 for clear instructions
Mar 06, 2011 | Lexmark X7350 InkJet Printer
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
X8350 InkJet Printer: my LEXMARK x8350 CONTINUALLY GRABS MORE THAN ONE S...
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
May 17, 2010 | Lexmark X8350 InkJet Printer
Black marks on the side of page
You are right the drum needs to be replaced. the coating wears down and starts making marks I sell them for 55.00 complete or just the drum for 22.00 It's easy to install a new drum with a screw driver and a pair of needle nose pliers. steven 818-888-0006
Mar 10, 2010 | Lexmark E250dn Laser Printer
Print job is totally black
I know you've tried some of the below suggtions but I put the whole list there for everyone else. If this printer is less than a year old call them. Their tech support has changed a lot! They try to take care of you.
Possible causes:
· Check/Replace the toner cartridge
· Check the charge roll assembly (see Note below)
· Check the Toner Darkness, Brightness, and Contrast settings
· Try cleaning the inside of the printer
· Bright light/sunlight entering the printer (on right side of printer)
· Printing on media other than plain paper (make sure you're using laser paper- it makes a difference!)
· Using a refilled cartridge. Lexmark will emphatically tell you they are not supported.
NOTE: Checking the charge roller:
1 Power off the printer and remove the toner cartridge.
2 Look into the upper area of the printer where the cartridge was sitting. Located near the top of the printer you will see a couple of gray rollers. This is the charge roller assembly. See the area highlighted in the image below.
NOTE: If you cannot see the rollers, close the upper lid slightly and the rollers should lower into view.
For larger version of this image, click here.
3 Make sure the roller assembly is seated correctly into the holders on the left and right-hand sides. If not, try to reseat the assembly into the holder arm.
IMPORTANT! If the charge roller assembly is not present, it needs to be installed. Look around the inside of the printer and near the printer for the roller assembly. If the charge roller assembly is missing, you will need to order a replacement set in order to get the printer operational again. See the 'Additional Assistance' section at the end of this document for more information.
4 If the rollers are present and installed correctly, check their condition. If the roller surface appears dirty, take a clean dry cloth and carefully clean off any dust or toner. Do your best to ensure all of the roller surface is clean. NOTE: If any part of the rollers is damaged, the charge roll assembly will need to be replaced.
CAUTION! Try not to touch the rollers with your bare hands. The surface is susceptible to contamination and a permanent mark could remain on the rollers.
5 If you were able to reseat the charge roller assembly or managed to clean the rollers, power on the printer and try printing again. Print 10 to 20 pages to give the pages a chance to clear up. If the pages do not begin to clear, the printer will likely require service to correct the issue.
For more information on arranging repair service, please contact Lexmark Technical Support or an authorized service center. See the 'Additional Assistance' section at the end of this document for details.
Jun 17, 2009 | Lexmark T644 Laser Printer
Lexmark t522 black marks on leftside of pages
the top roller is the charge roller and the bottom one is the transfer roller if a foriegn substance got on either roller they could create this problem the oil from your fingers getting on them could create this. given everything youve changed the rollers are whats left. you can clean the charge roller but its better to get new ones these are consumable
Apr 22, 2008 | Lexmark T522 Laser Printer
Lexmark E232 Laser Printer Logo
727 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
