Question about Relisys Televison & Video
Turns off after turning on
I have a relysis lcd tv LV87E and i tried to turn it on and it fashes off again.Can you help with this problem
harry0000010
  • 40 Answers
SOURCE: Akai LCT2721AD 27 in. LCD
sounds like the pwr supply is suspect....
Posted on Jan 27, 2008
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
budmrtn
  • 11361 Answers
SOURCE: HELLO. I GOT A LCD TV LTV 32W3. I TURN ON AND 30
I just fixed my today, you need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
Posted on Dec 28, 2009
dsacco86
  • 1077 Answers
SOURCE: I have a LCD Color TV, but when turn on, green
The most common problem is the Power/Backlight Inverter Board. There are 6 mini transformers on the board, one goes bad and the TV will turn itself OFF automatically for " Protection Mode". Replace the whole board or replace the bad mini transformer.
Part number#
Whole board, BA71F0F01042
Mini Transformer, LTZ2PC0MS008
Posted on Mar 02, 2010
cirocpatel
  • 524 Answers
SOURCE: got new tv Westinghouse LTV-32W1 32 Inch
in this case i have to know if your tuner is working fine or not. First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board. Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board. Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns. Also rate me if you like this post.
Thanks.
Posted on May 11, 2010
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
I have a 32" LCD
Tries tv turn off and turn on again about an hour later,see if the tv do resetting,tv might be back working to normal again.If still have the same problems.The tv have 1 or 2 long boards that call LCD inverter boards.These 1 or 2 long LCD inverter boards are dead.These 1 or 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the LCD screen panel to produced a pictures.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter board for the replacement.
May 13, 2011 | Televison & Video
My Dynex 19" LCD TV
try to disconnect all external devices connected to your LCD TV then try to turn it on again then wait for a minute. if the problem persist you need to get it serviced by Dynex.
hope that helps.
Mar 24, 2011 | Televison & Video
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Regards;
VOTIT
Apr 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
I need a code for a tevion universal remote
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Dec 01, 2008 | Universal Remote Control 6-Device...
P990i not turned on
re-program d fone then try 2 turn it on again
Aug 07, 2007 | Sony Ericsson P990i Cellular Phone
Televison & Video Logo
89 people viewed this question
Top Relisys Televison & Video Experts
CoppellTVRepair.com
Bill Boyd
Are you a Relisys Televison and Video Expert? Answer questions, earn points and help others
