Question about Freezers
Campmaster fridge manual - Freezers
Fridge part freezes up , lost manual cant work out what the on/of switch is meant to do?
If this was my fridge
1 I would give it a soft kick with my right foot/ your left
2 nothing happens
3 empty the fridge
4 push the off switch
5 should the unbeliveable happen that the frozen part would start to melt
6 then I put some boiling water in a wash basin in the fridge and a few towels on the floor-we don´t want water on the floor, do we?
7 when all the "frozen places" have disapperaed .
8 clean the fridge´s insides
9 push the on button and close the door properly
10 wait for 30 min open again and see if the places that are supposed to be frozen arn´t frozen
11 if they are put the good things back into the fridge
12 and have a good cup of coffee
Good luck
kollagunn
Jun 04, 2011 | Freezers
I have a Woods refrigerator that is all fridge, no freezer compartment. Model # RFA17NAC. s/n 07605297JG. It is leaking water on the inside of the fridge and collects on the fridge floor. No manual came...
Hi Linda. We have the identical model of Woods all-fridge and
experienced this problem several times over the course of several
months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs
from the inside rear of the fridge down to the catch tray (underneath
the cabinet, next to the floor, behind the kick-plate) is sufficiently
plugged (with some kind of gunk, probably from a spill inside the
fridge) to cause a back-up. I suppose the inner diameter of the tube is
maybe 3/16" so it can easily get clogged. Consequently, the water runs
down the inside back of the fridge & eventually ends up in the
depressions below the crispers. In our case, after those depressions
filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube
but I didn\'t get it all out. Just enuff to let some of the water get
thru, but the tube would plug up again. After a few repeats of the
problem, separated by a month or 2 each time, I decided a more "drastic"
tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube
completely, but I didn\'t have that available so I had to use a
semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5
yrs. since that more thorough tube cleaning & the problem hasn\'t
come back, so I think the tube got plugged from a spill in the fridge
(which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is
accessible from behind the fridge. I didn\'t pull it completely out
(which might have disconnected it from its fitting), I simply reamed it
out while it was in-place.
Hope this has been of some help to you.
Norm.
Aug 26, 2010 | Woods Upright Freezer MU07W
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Mar 29, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Fridge and freezer both freezing
If your control is not turned up too high you likely have an insensitive one. In this case it needs to be replaced with a new one, not too serious.
Dec 18, 2008 | Kenmore Freezer 20.6 cu. ft. Manual...
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
FRIDGE FREEZER
What freezer not above.
Thanks J
Jan 03, 2008 | Freezers
Belling fridge/freezer controls
most likely that is an on off switch for the temperature alarm. the 1 or l is the on psosition and the O is the off postition..
Nov 16, 2007 | Freezers
Freezers Logo
62 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
