Question about Epson LX-300+ II Matrix Printer
Epson LX 300 + II printing funny characters - Epson LX-300+ II Matrix Printer
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
SOURCE: Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Posted on Feb 20, 2009
SOURCE: setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Posted on Jul 29, 2009
SOURCE: Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Posted on Feb 24, 2011
SOURCE: hw to reset epson lx-300+II
one pin don't work
Posted on Apr 03, 2011
Hello guys, how can i change the LX300-ii font spacing. thanks in advance.
You can download user's manual where it explains how to use your printer's control panel to change one of 6 inbuilt fonts.
read this short tutorial
http://maintenanceprinter.blogspot.com/2011/07/how-to-change-fonts-in-epson-lx-300.html
Download manual:
Descargar Epson LX 300 II
I guess you can change fonts using control characters but I don't know if you can embad tham in a word doc. No way to test it because I don't have this printer.I remember having done it in early days of DOS word processing with Wordstar.
Hold ALT and type the command character - the numbers 27. In notebook will look like an arrow to the left, followed by writing a command character, examples:
? P Selects 10 cpi
? M Selecting the 12 CPI
? ? Select dense Print - 15 CPI (this character is typed by holding the ALT key figures 15)
Nov 09, 2015 | Epson LX-300+ II Matrix Printer
Cara reset LX 300+
mohon dibantu nih... pake printer epson lx-300+II , kalo print dari dokumen bagus , tapi dari browser huruf & angka numpuk. Makasih....
Mar 09, 2012 | Epson LX-300+II Matrix Printer
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
My epson LX-300 printer got wrong. it's printed strange character seem wingdings character. i used continous form, LX300 pulled the paper over n over. pls tell me how solve it tks
either corrupt drivers, or bad print head. Try reinstalling the drivers for the printer. Otherwise, the problem will be more expensive to fix then to replace the printer.
Apr 30, 2009 | Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Nov 05, 2007 | Epson LX-300 Matrix Printer
Epson LX-300+ II Matrix Printer Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
