Question about Seagate Computers & Internet
Miray hdclone error - Seagate Computers & Internet
Codigo televisores miray
0746 0759 0798 0361. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
May 25, 2014 | Televison & Video
Tip
Cloning Disks
Cloning an existing hard drive, whether it is a HHD or SSD can sometimes be very frustrating. Using the disk drive manufacture's cloning software does not always work, it may report allocation size, block size or sector size as being in compatible between the two disks. I have spent a great deal of time trying the different suggestions on the web to fix this problem and none seemed to work, that is, until I came across HDCLONE.
This is a free software utility that automatically corrects these incompatibility issues. The software can be found at www.hdclone.com . I have used this software to clone disks for two different laptops and I have not had any problems. I think the only limitation is the destination disk for the cloning must have a larger capacity than the capacity on the original disk. I cloned from an installed hard disk to a USBSSD and to a HDD/SSD hybrid disk and the cloned disk booted up and worked fine.
This software can be used either to clone an existing small disk to a larger disk, or making a backup disk that can be installed and used if necessary.
The cloning process from a 500Gb to a 1Tb disk took most of the day, so I would suggest you start the process when you go to bed so I will be completed by morning.
Let me know how the software worked for you.
on Nov 27, 2017 | Computers & Internet
Hard disk drive ps2 slim
The PS2 has a replaceable hard drive. If you would like to keep the information/games from the original drive, Sony uses a special file system. You need to perform a 1 to 1 clone using HDclone or Acronis cloning tools.
Feb 02, 2014 | Toshiba Computers & Internet
I want to know can I clone the hard drive via usb. thank you
Hello! All you need to do is have both hard drives plugged in, and open the windows where you are transferring the data from and the data two, highlight all of the files on one hard drive, and drag and drop it into the new hard drive.
May 06, 2011 | Toshiba 40GB 5400 RPM NOTEBOOK HARD DRIVE...
I want to clone my hard drive to upgrade it from 320GB to 1TB. I have a slimline PC, and do not have room to have both hard drive's in the PC. I was going to purchase a gadget called: HD Copy Box, Dual...
No need for it. just open the case, attach the new hard disk and leave it outside for the moment, then use this to clone it
http://www.miray.de/products/sat.hdclone.html
Later create another partition in the free space and use it for your files - so you don't lose them if you have to reinstall Windows.
Jan 11, 2011 | Computers & Internet
Friend bought used Gateway 1200cs w/win xp and no disks, she wants to put new HDD in and I need to make a disk to re-install windows or copy it to a partition. how to?
Some HDDs come with a cloning software - get that. Then you won't need to redo the operating system. However, if you have the original operating system disc, it has provisions to create another partition, but you want to install a new HDD. If I understand you correctly, she wants her old data in the new HDD - that's a separate issue. If I were you, I would just install the new HDD along with the old HDD together and have the old HDD run the operating system.
Dec 22, 2010 | Microsoft Windows XP Home Edition
Help to backup full computer programs & docs with WD Passport 160
Try going to the "Computer" icon and look for the external drive. Open the ext. drive folder and look for the InstallSeagateManager icon, the Application one. Double-click on it and it will allow you to install the software to do a backup on your new computer. First thing you should see is the Language Selection screen. I think you can take it from there!
Sep 22, 2009 | Western Digital Passport (WDXMS1600) 160...
Hard drive partition...
Depends on what cloning software u using, you can still try Partition Manager 9.0 ...
hope that helps...keep the hope :)
May 19, 2009 | Dell Inspiron 6400 Notebook
URC-3220 HELP
instrucciones para meter codigo a una tv sanyo con control remoto urc-3220
Aug 11, 2008 | One For All URC4110 Remote Control
Computers & Internet Logo
15 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
