Question about RCA Scenium D40W20 40" Rear Projection HDTV
My tv turn on an off still
Its a rca d40d20 tv it turns on an off 3 times then dosent work for 5 min has anyone found out the problem yet. if so could you post how to fix it. thanks phil
  • Anonymous Dec 10, 2007
    I have same problem, wil you let me know if you have figured it out yet?
Have you recently replaced the bulb? if so, make sure you flipped the latch switch all the way down in the locking position. If you didnt it will not make good contact & will cause it to turn off & on.
It will also do this if your cooling fan is not working. The bulbs cause a lot of heat & if the fan(s) arent working properly, the tv will overheat & will turn off.
Posted on Nov 03, 2012
We layed it down to insert the brackets
Posted on Nov 23, 2007
The Tv will turn on and work for 5 min then shuts down
3 lights on front flashing indicates lamp quit. Could be lamp or ballast.
Apr 10, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Tv wont turn on ? makes a noise but dosent come on and no burnt boards
I have a 52inc RCA t.v the t.v light turn on then turns off 3 time
Mar 01, 2010 | RCA P52926 52" Rear Projection Television
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | RCA TruFlat 27F520T 27" TV
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
RCA P52937SG
Time to replace.
Mar 10, 2017 | Televison & Video
TV will not turn on
can you respond to this same post and let me know if it blinks 3 times or what the number of blinks is and I will try to assist you.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 screen flashing and won't turn on
YOU DO NOT HAVE ANY LAMPS --BUT YOU DO HAVE 3 PICTURE TUBES...SORRY TO SAY BUT THIS IS THE WORST TV BUILT...LETS SEE IF WE CAN FIND A FIX...YOUR PROBLEM WILL PROBABLY NEED A SERVICE TECH BUT HERES SOME OF THE PROBLEMS THAT GO WITH YOUR SYMTOMS---WHEN THE SET TRIED TO COME ON WITH 3 FLASHING BLINKS,,IT'S GOING INTO SHUTDOWN...NOW...THE HV TRANSFORMER,,THE HV BLOCK AND SOME CASES ,,,ONE OF THE PICTURE TUBES LEAKING FLUID AND SHUT DOWN...CHECK UNDER THE TV FOR A FLUID LEAK-LOOKS LIKE ANTIFREEZE-THE WHITE STATIC THING SOUNDS LIKE HIGH VOLTAGE ARCHING...AFRAID YOU'LL NEED A CHECK OUT FROMM SERVICE TECH..TUNICA
Sep 01, 2008 | RCA P52926 52" Rear Projection Television
RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Scenium D40W20 40" Rear Projection HDTV Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
