Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Plugged in not charing, power available 92%
I bought my laptop about 1yr ago suddenly today i saw an icon showing plugged-in not charging when i removed the AC power cable the lap top shuts down immediately and i get inproper shutdown when i turn it on on an AC power supply.
when i move the cursor over the battery icon still indicates the same. tried to remove the battery from the unit for a while and then placing it back turning the pc on still gets same results.
can a battery die with charge still 92% power available and not able to power on my pc with out AC support ?
what should i do if my warrant has expired?
  • amagesa Jun 21, 2009
    I TRIED WHAT YOU HAVE INSTRUCTED but the problem still persists. this morning the bayyery meter is reading 93% instead of yestardays 92%. but cant use the battery on its own to power my laptop.
    the lead indicator for battery lights on for a second then goes off.
    is there any other solutions to my problem
  • 3 Answers
Shutdown PC. Then remove battery and Plug in AC power cable. Boot Computer. If everything fine, then shutdown again>put battery back and try! It should work. I had similar problem.
Posted on Jun 18, 2009
Champ 3303i battery not charging
The battery or charger may be defective
Mar 29, 2017 | Cell Phones
I just bought my new macbook air today, and suddenly after playing with the text to speech to iTunes- the sound stopped altogether, i get nothing. I just bought this a few hours ago! what do I do?
Open System Preferences, and click on the Sound icon. Under the Output tab, make sure "Internal Speakers" is highlighted, and the "Output volume" slider is not all the way to the left.
If that is the case, take it to the Apple Store and have a technician look at it. Since you only got it a few hours ago, they'll fix any issues free of charge. (It's under warranty for a year)
Sep 08, 2011 | Apple MacBook Air
I bought a Dell Inspiron 1318 about 3 years ago, new. About a year ago my battery stopped taking a charge. I just decided I needed to buy another battery online from BattPros.com. I followed the...
Hi
Check this
When your shut down your computer and plug your the charger in your laptop that time Orange lite is showing on. if no showing then its problem to your laptop
Jun 05, 2011 | Dell Inspiron 1318 Laptop Computer PC...
My aspire 5740 showes 81% available but not charging, checked all power lines etc on balanced power. Bought laptop 3 weeks ago till today it charged up
Hi
Dont be panic. Your laptop has absolutely no problem.Your manufacturer had set a 80-20 policy for the laptop battery charging such that the battery wont be charged to 100 percent but it will charged only upto 80 percent. The makers of the lap are doing this because to give good life to the battery.You can change it by going into the power options inside control panel.
Mar 23, 2010 | Computers & Internet
I just bought a new laptop yesterday and when i plug in the chager it dont chager it said plugged in not charging so idk what to do thankxs
On the front of the laptop or near the screen you should see a light that shows one color for when it is running on battery and another when it is charged. Usually yellow when charging and green when charged.
As well when you boot into windows near the clock you will see either a battery when using the battery, a plug with a lightening bolt when charging and just the plug when you are 100% charged.
In your user manual you should find a few picture that show and explain where and what all the light or indicator mean. If you go under control panel ot right click the icon near the clock then you get into the power panel.
If you are new to laptops it is a good idea to have the manual open and go over everything to familiarize yourself with what and where. Then you will avoid what I did when I first bought a laptop and couldn't get the wireless to work. If only someone had read manual and saw where the switch was ;-] Enjoy your laptop once you get used to things they are hard to be without.
Nov 04, 2009 | Dell Inspiron 1525 Laptop
Pa-19 power supply for my Dell m1730 is broken
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 08, 2009 | Dell XPS M1730 Laptop Computer PC...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
241 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
