Question about Verbatim Corded Mice 49003 Mini Travel Mouse - Mouse - Optical -
Driver required for verbatim 49014 mouse - windows 7 64 bit
Plug and play method not working on some usb ports on system - all other devices works on all 4 usb ports but mouse only work on specific one usb port
SOURCE: Verbatim Thumb Drive problem
Download the following, I had the same problem and then this worked. Version 1.2.0.4
http://www.verbatim.com/support/support-article.cfm?support_id=858682BD-1422-1392-A8E8CBC9CA6CFE95&supportType=Download
Posted on Jul 22, 2008
  • 272 Answers
SOURCE: USB external hard drive does not show up on OS X desktop
You need to be sure that it is formatted as a FAT32 drive and not as a NTFS. When you are in Vista right click on the drive icon and click on properties. You will see NFTS or FAT32 under file system. Your drive must be FAT32 to be recognized by a Mac. Iomega.com has a FAT32 formatting software that you can download for free on your Vista PC and re-format the drive as a FAT32 drive.
Posted on Apr 25, 2009
lserni
  • 466 Answers
SOURCE: Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Posted on Oct 27, 2009
SOURCE: verbatim mouse 96150 is not working new battery
What I do to make it work on my xp, vista, or w7 computers is to first plug in the usb device then push the button on the device and move the mouse. if that doesn't work, then I open the battery case and remove one of the batteries (with batteries closest to you, the one on the right has the positive + terminal closest to you). Now when I move my mouse it works every time (if the batteries are charged)
Posted on Dec 30, 2009
SOURCE: verbatim usb500 drive just clicks when connectted
my kingston 2 gb pen drive is not working
Posted on Dec 31, 2009
I have an HP TouchSmart 600. When it was updated to Windows 10, it no longer recognizes the Mad Dog external hard drive (model: MD-AEN350COM), and does not show it in file explorer.
I'm a bit of an expert on storage systems. (for sure externals)
it's a SATA HDD in a box with USB cable right?
mad dog,
did you :
1: use the power pack for it> (it came with it) use that !!!
do not tell me it works on other PC lacking that pack
we KNOW THAT aND WAY, (POWER ISSUES)
The usb ports can not run that hdd startup currents on vast numbers of Laptops with gutless 100ma usb ports. a fact.
2: next try all USB ports, test the ports with mouse to see that The USB port is even good, at all? next.
it must show up in disk manager first not explorer, its windows and that is a fact. (SEEN IN COMPUTER MANAGEMENT OF CP)
3: are you web connected?, when plugging in the USB cable.
if not , do not expect drivers of any kind to work .
steps:
a: PC on.
b: power pack connected to mad dog, put ear to MD case hear the drive spin, if not the power pack is bad, or the drive is dead.
c: plug on the USB cable last, hear windows(be web connected) go
DINGGONGSOUOND? it not the port is dead, try all USB ports
try looking in DM to see if USB ports are dead, some older laptops have USB3 ports that windows has missing drivers, and must be hand loaded by you to make uSB3 work(ask me how)
so try all USB ports. try a mouse on them all , all USB ports must work with a simple mouse. if not use only those ports that work with the mad dog.
http://www.pcdied.com/external-hdd.html
dingdongsound = ms windows-system-sounds, called DEVICE connect, have volume up, and that enabled and you will get that sound for any USB connects.
try a mouse or usb stick on all USB ports to prove the all work. first.
then play with HDD. external.
May 23, 2018 | HP Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Why won't the right USB port recognize when I plug in my mouse?
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Sep 16, 2014 | Dell Inspiron Computers & Internet
How do I update my wireless mouse?
try updating the mouse drivers. Go to the Verbatim manufacturer website, search your model of mouse and download the latest driver. To update drivers on windows go Control panel>device manager>mice/input device then right click your mouse and update driver software. If the mouse continues to play up even though it works on other computers then the mouse is probably incompatible with your operating system.
May 01, 2014 | Verbatim Cordless Mice 96898 Nano Wireless...
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Plug & Play recognises Dub E-100 attached and device manager lists it however continually get error 39 driver missing or corrupt. Drivers loaded directly from CD supplied / also download version...
Hi.Try to install again your windows xp.need fresh windows xp installation because same of your operating system software device corrupted and missing.to recognizes that USB network adapter gadget.
Jun 09, 2011 | D-Link DUB-E100 (DBDUBE100) USB Network...
Ok i have this mouse that does not work when i plug it into the usb port. the mouse dosent light up or any thing... what do i do?
First thing to do is to determine which one is at fault : is it the mouse, or the other way around?
Here's how :
  • Try another (known working) USB port
  • Try the mouse onto another known working computer
  • Try another known working mouse
  • Try another known working USB device (flash drive, etc) on USB port
Typically, the mouse needs replacement if it still does not work with another known good usb port or computer. If it's the other way around, then you may have USB port issues with your system.
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Verbatim Corded Mice 49003 Mini Travel Mouse - Mouse - Optical - Logo
57 people viewed this question
Top Verbatim Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Verbatim Audio Player and Recorder Expert? Answer questions, earn points and help others
