Question about LG Microwave Ovens
My LG-MS-2022G is coming on but will not warm the food, what should I do?
Some users have been using aluminium foil in the oven, could it have caused damage to the magnetron
    Scholar:
  • 126 Answers
It's my understanding that aluminum foil can reflect the RF energy back into the magnetron and causing it to overload and fail. If the oven turns on but does not heat the food, you can just about bet the magnetron is shot.
Posted on Apr 14, 2014
  • Ted H May 05, 2014
    Hello, Wezi. If the magnetron has failed, you should get an error code related to under-current in the magnetron power wires. It's quite possible that the problem lies within the control circuit board and/or the relay that supplies power to the magnetron. My 'over-the-range' unit also has a failing 'door closed' switch near the hinges and if the door is not detected to be closed, microwaves are not generated. However, when this happens, the timer does not count down. The door switches (mine has 3) are about $2.00 each at your appliance parts store and replacing it (or them) is quite straight forward once you get access to the hinges.
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave will not heat food
Found this under Maytag instead of LG, but will be happy to help.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Magnetron diagnosis is here: http://gallawa.com/microtech/mag_test.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 08, 2007
SOURCE: Microwave oven coming on but not heating
I had the same problem with my Sharp OTR microwave/convection oven. I had 2 service reps out to look at it (Sears and Lowes) they both said it was the magnatron and would cost about $500.oo to repair it. I called Waverly's Appliance in Paris, TN and it turned out to be a diode. Total cost of repair was $35.00 including service call.
Posted on Jan 09, 2009
Arius
  • 446 Answers
SOURCE: magnetron antena metal cap hole due to spark
it is not safe to use this, DO NOT USE, repalace immediately, no need to repaint
Posted on Mar 22, 2009
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
localwonder
  • 6784 Answers
SOURCE: My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
Posted on Jun 01, 2009
I have an lg convection microwave oven. Can I use foil while using convection roasting?
The instructions for using your oven should may it clear that a number of materials, including foil, have no place in a microwave oven.
Mar 04, 2017 | LG Microwave Ovens
Heat: I placed a microwavable food product in my sharp carousel r-1505. there was a tiny piece of the foil still attached to the rim of the product container. upon start, the foil immediately caught...
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sep 22, 2013 | Sharp R-1505 Microwave Oven
The paint came off because my grandaughter put aluminum foil in it. How can I repair the paint?
I would like to make a warning ,do not try to repair microwaves , they are lethal weapons , I know someone who ran one with the cover removed and cooked his kidneys , if it is faulty dispose and get new, if aluminium foil was put inside it has heated up and as you say damaged paint ,the seal could also be damaged and lethal , dispose and buy another .
Mar 22, 2012 | Kenmore 63252 Microwave Oven
Can we use alluminium container for baking cake
You can use an use aluminium foil containers, the very thin type. Use an ordinary thickness metal container, including aluminuim, and you will most likely blow the magnetron. Rule of thumb:- If in doubt, keep it out!
Apr 03, 2011 | Samsung Microwave Ovens
Would like to know how to use the Inverter. Is it for baking & defrosting? Have never used one before and do not have a manual.
Hi ifcope2000,
The inverter in your oven is for defrosting. It works on the basis of weight of the food to be defrost. To use the inverter follow the following steps.
First place the food on the microwave dish and then close the door.
Now press Inverter Turbo Defrost.
Enter the weight of the food using the number pads.
Press Start.Defrosting will start. The time will count down. Larger weight foods will cause a signal
midway through defrosting. If 2 beeps sound, turn over, rearrange foods or shield with aluminum
foil.
Atul
Mar 13, 2011 | Panasonic Microwave Ovens
Aluminium foil melted on Smeg black schott ceran cooktop. Too stubborn for razor blade. Any suggestions?
Sorry to read about your problem, I hope this helps you out.
try some oven cleaner, and let it soak...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Microwave Ovens
I covered the plate with 'heavy duty aluminum foil' thinking it was safe for for microwave use, then I saw a sparkle inside while turning. I stopped it, took off the aluminum cover, turned the microwave...
The food is safe as long as the food has not got oxidized aluminium on it.
Microwave energy is very high and will melt metals!
As long as it is not arcing any more there should be no problem.
Jan 03, 2011 | LG Microwave Ovens
Aluminum foil was accidentally put in microwave. Microwave turns on as usual but now does not heat foods.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ..
Oct 25, 2010 | LG Microwave Ovens
I accidentally covered a plate with foil in the microwave. there was Arcing (no fire) and now there is black marks etched where the foil touched the sides. The cavity seems unharmed though, it seems if I...
Sometimes the arcing itself will cause black marks inside the oven. The places where the foil was melted, (touching), likely left small metal deposits, possibly now, impregnated in the surface. It is important to remove these if possible to avoid further arcing. Remove these then test to make sure the oven is functioning properly. If so, continue to use.
Jun 22, 2009 | LG LRM1260SW Microwave Oven
Microwave Ovens Logo
136 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
