I need an owners manual for a washer
I bought a used Whirlpool Duet washer and dryer. I need a manual to learn all the ins and outs of using the washer... help!
  • 111 Answers
SOS: We bought a used Whirlpool Duet sport washer and dryer, which the owners said were about 2 1/2 to 3 years old. We do not have manual for it so cannot figure out why the washing machine window blinks...
F-20 on display (Water Inlet Problem-no water or insufficient water supply)
  1. Select PAUSE/CANCEL twice to cancel the cycle.
  2. Unplug washer or disconnect power.
  3. Are water faucets completely turned on?
  4. Are screens at inlet hose connection clear of obstructions.
To view the manual in an Adobe PDF format right click and select open to go to the owner's manual site.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WFW8400TE&siteCd=MT_EN_US&userType=Consumer
Feb 22, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Need exact dimensions of duet washer & dryer bought in 2006. Also how to prepare for moving same appliances.
Basic measurements for washer and dryer with door closed and not on optional pedestal(s) are 31.5" deep (front to back), 27" wide, (left to right), and 38" high. For installation and usage consider the leveling feet, use of pedestal(s), water hookups, drain hose for washer, and vent (exhaust) hose for dryer. You may want to position the washer on your left, and the dryer on the right due to hinge location, and for ease of transferring laundry from one machine to the other. Depth of washer (front to back) with door open 90 degrees is 50.5" and the dryer is 51.5". At the factory, four (4) shipping bolts are attached to the back of the washer to secure the drum for shipping. These should be re-installed prior to the move, (if you still have them). To see the supporting documents, go to; http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/ewpl_mic_604_021.pdf
I hope this helps you as well as others. Please rate my answer. Handiest1. 10-1-10
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer Lockout function stuck
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Long cycles on my whirlpool duet washer
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer
Try pressing the End of Cycle button on the far right and holding it for more than 3 or 4 seconds.  It should reset.
Jun 01, 2008 | Whirlpool GEW9250 Electric Dryer
Washing Machines Logo
803 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
