Question about Sanyo 24K40 24 inch Multi-System LCD HDTV
Sanyo 24k40 lcd screen damage
Replace
2 Suggested Answers
  • 20 Answers
SOURCE: We just had a lightning storm come through which
I've checked on line for a schematic of this TV but was unsuccessful but I suspect it is one of two problems.
1) A fuse inside the TV was blown from a power surge caused by the storm. If you can locate it pull it out and look to see if it looks blackened (even a little) or if the wire inside is broken. This would indicate the fuse did it's job and stopped the power from burning out the whole TV. All of these fuses are available at your local electronics store or Radio Shack if you have one nearby.
2) The power supply on the TV was hit by the surge and burned out. There is no simple solution to this problem as the power supply would need to be replaced and the only way to do this is to hire a qualified TV repair service. If you happen to be good at soldering and understand electronics you could do this yourself after buying the power supply on line. I checked online and the part is about $60-70 USD.
There is a possibility that the power surge could have fried one of the circuit boards and if that's the case then you would have to weigh how much you want to pay to repair the unit after having a repair service estimate the work. I feel pretty strongly that you have one of the other two issues I listed since you didn't mention any other items in your home that were damaged at the same time. If there were more items then I would suspect the power surge would have been much more massive and likely caused considerable damage but since not then the damage would be minor leading to my previous conclusion.
Posted on May 23, 2011
How I unlock my Sanyo lcd 24k40 .i also lost my remote
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Sep 01, 2016 | Sanyo Televison & Video
LCD-24K40 SANYO NO POWER
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 02, 2016 | Sanyo Televison & Video
SANYO LCD 24K40 TV instead of Red or Green the power indicator display Amber color
press the helpful button,
the amber light may be for stand by or sleep mode, go into your tv setup and check that these are turned off
Jan 12, 2016 | Sanyo Televison & Video
Locked accidentally. How can I unlock it?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Jul 23, 2015 | Sanyo 24K40 24 inch Multi-System LCD HDTV
How can I unlock my Sanyo TV set
Without its remote control; you can't unlock it.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Gopakumar Gopalan Google
Aug 06, 2014 | Sanyo LCD-24K40 MULTISYSTEM 24 INCH LCD TV...
All key is locked
Just unplug the TV from AC mains wall socket and re-plug it back after 10 minutes or so. This must reset the TV to a "Hard Reset". If this do not help you, have to enter its service mode options.
Dec 31, 2012 | Sanyo 24K40 24 inch Multi-System LCD HDTV
No video but sound ok
A 24 inch set may not be economical to fix for this issue---most LCD sets use some type of back lights---take a close look to see if anything is on the screen even if very faint.
Problem could be power supply related or main board related (it processes all signal and controls the screen).
If as indicated it is a multi-system set parts may be hard to find.
Weigh the cost of the unit versus repairing or buying a new one.
May 17, 2012 | Sanyo 24K40 24 inch Multi-System LCD HDTV
How to reset the TV menu on my sanyo vizon 24k40?i think a menu pop out and someone in the house mess it up?can't access the whole menu and remote control isn't working?
Hold down "INPUT" Button at TV panel, while you press "INFO/A-B" button in your remote.. Or...Hold down "INPUT" Button at TV panel, while you press No.1 chnl on your remote..
Sep 04, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have both lost my remote and activated the child lock on my Sanyo LCD-24K40. How do I deactivate the lock without the remote?
Most TVs will have a "Press for 5-10 seconds" unlock function.
Usually it's holding the power button that unlocks it, but if that doesn't work, try all the other panel buttons in the same manner.
Jun 18, 2011 | Televison & Video
Sanyo 24K40 24 inch Multi-System LCD HDTV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
