Question about Toshiba REGZA 47HL167 TV
Toshiba 32" regza TV great picture but no sound how can I solve this please.
Turn on the TV great picture but no sound...it eventually comes through about 1 hour later Any ideas how to fix please?
    Top Expert:
  • Toshiba Master
  • 75,599 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 14, 2014
ctf1800
  • 4402 Answers
SOURCE: Toshiba Regza 32"
I would return it, sounds like the bulb died.
Posted on Feb 22, 2008
SOURCE: Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
Posted on Apr 02, 2009
romsky79
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
SOURCE: Can't remove base-mount from Toshiba REGZA 46
Go to http://www.youtube.com/watch?v=rWAJqNVTqug.
The secret is locating a total of four hex (or in some models - 5) screws located at either side near the bottom at the back of the unit.
Posted on Jul 04, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
Sound but no picture
no bulbs to replace here, i might have better news for you. Toshibas with this time frame has an inverter problem. turn tv on tilt back wards at 45degree angle and flack a light to the screen and look closely if you can see the image the replace the inverter units. to help you see hit menu on remote, the menu is white so will make it more visible. If you did want to replace the inverters they are like 60-80 $ for hte pair and simple to replace.
Apr 27, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
No picture, no sound. tv less than oone year old. toshiba 32" HD TV. Failed without warning
GO IN TOUCH WITH TOSHIBA AS THE SET WILL BE UNDER WARREN TIE ........SO FREE REPAIR AND SERVICE
Nov 19, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
I have a 32 " 1080 PI LCD Regza. Have audio but no picture. Menu items come up on screen, but no input from Sat. Box, Xbox etc..
check your power supply. and check your
invert board back lamp driver if you have a
miltmenter check your vote at the invert board.
if you do have the rigth volt yiu have a bad invert board.
Aug 10, 2009 | Toshiba REGZA 47HL167 TV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Hdtv-dlp has no sound or picture
this sounds like a dmd board problem. these are digital modules attached to the light engines usually. samsung, rca, hitachi, have shown similiar symptoms. some units have capacitors on the boards that can be replaced, but these are dual-layer pcb's that are tough to unsolder without proper soldering iron temperature and good small gauge solder-wick. or solder pump tool. the electolytic caps. are usually 1000uf / 10v, 330uf / 10v, or 470uf / 10v. alot of the time the capacitors will "vent" or swell-up on top which helps spot faulty component. we always increase voltage rating to 16v-25v for more reliable operation. always use 105 degrees high- temperature replacement caps.
Mar 08, 2009 | Toshiba 32HL67 32 in. LCD Television
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Feb 17, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
No sound
have you checked the connections and what is hooked up to the tv do you use a receiver or surround station to produce sound and did this just happen? please more info.
May 27, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 47HL167 TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
