Question about Ambir Technology DocketPort 485
Computer can't "see" scanner even though plugged into USB port
Tried changing cables in case the first one was bad. Tried the other USB port. Am out of ideas!
Error message: "Scanner not found. Please check the hardware connections and try again."
Thx.
    Sergeant:
  • 338 Answers
Please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Posted on Jun 18, 2009
My Kindle Fire will not start
If you last charged it with the computer USB port, try charging with the supplied AC adapter instead. If you last charged with the computer USB port, try charging with the AC adapter this time. This will help isolate a bad AC adapter / power cord or USB cable / USB port.
It is important to note that if you are charging your Kindle via USB port on a computer, when many computer enters "sleep mode" the USB power is shut off at this time too. Charging is effectively halted - even though still connected. You should only expect to charge while the computer is active or when using the AC adapter.
You can also purchase an aftermarket DC charger. These are small plugs that are inserted into your auto's port or cigar lighter. They provide 1 or 2 USB connectors to plug in a USB cable. These devices are suitable to supply / charge just about any devices that uses a computer's USB port to power / charge a device. They cost anywhere from $5 and up and look something like this:
I hope this helps and good luck!
May 22, 2012 | Amazon Kindle Computers & Internet
When I press the scan button, the error USB not connected appears even though it is connected.
You will need to install the software that came with the printer on the computer that it is connected to. The software will then run on the computer and "listen" for a command when you press the scan button. What is the make/model of your printer?
Feb 28, 2011 | Computers & Internet
Epson perfection 2580 scanner will not start. Programs installed w/cd. Epson updates added. Just says" scanner can not start"
The first thing to try: a new USB cable and a different port. (If you are using a hub, try directly connecting to the computer). What does the device manager say about the scanner? (In Windows, access from the Control Panel > Hardware. Exact directions depend on the OS version.)
Check the transport lock on the bottom of the scanner - do not put the scanner on its side when you check the lock.
Make sure the scanner was on and had already warmed up (stopped blinking) before you tried to start the scanner software (either by the buttons or from the scanner). You may want to reboot the computer (in case the computer thinks one program has locked access to the scanner).
I hope this helps.
(scanners require two-way communication with the computer and a bad cable will stop the scan even when the computer sees the scanner and the software installed without a problem.)
Apr 26, 2010 | Epson 2580 Perfection Photo Scanner
4200F scanner functioning intermitantly
Hi
Please Use the in your computer usb pci cards it will work..
and My computer  right clickManagego to the Device Manager Scan for hardware changes..
check it..
Nov 18, 2008 | Canon CanoScan 4200F Flatbed Scanner
How to attach outdated hardware cable to computer w/usb ports?
Hi!
I'm not really sure what you're asking. If your problem is that your scanner has an "outdated" connector and you want to try to connect it to your PC via USB ports, the only sensible answer, given the prices of scanners, is to buy a new scanner. Your old scanner, if it is not USB, is probably a SCSI connector device. Do a Google search exactly like this "USB to SCSI adapter cable" and you'll see a lot of results. Cables generally seem to range from $20 to $100. Even if you get the scanner connected, there is a very high probability that there will not be any drivers available that will work with the new computer and cable. All-in-all, a new scanner, even a cheap one, is the way to go IMO, and will give you better scans to boot.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | HP ScanJet 3200C Flatbed Scanner
Canoscan lide 70 stopped working
Disconnect (unplug from power outler) PC from power cable for 10 mins. Unplug scanner. Restart pc, plug back scanner. Restart PC and check if it works.
If it doesn't start you may need to reinstall drivers .
Driver from Canon site
Driver from other site
regards
Mar 12, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Replacement USB port for my scanner, how can I find the one I need?
If you mean the USB Cable (not USB port as in your question) then you need a standard 'computer to peripheral' cable. It has the regular USB rectangular plug on one end (this part goes into the computer) and an almost-square plug on the other end (this part goes into the scanner.) I say "almost" square because it has two rounded corners to help with orientation.
As additional reference, these types of cables are commonly used to connect USB hubs to computers. For example, the USB hub built into my Dell monitor also uses this standard cable.
One end:
Other end:
Dec 16, 2007 | Epson Perfection 1250 Flatbed Scanner
ScanCraft CS-P always says there isn't a scanner connected or that there might be something in the parallel port
Evening MCRmyFranKIE, A parallel port is commonly known as a printer port or LPT1 port. Before USB ports existed scanners frequently used them to connect to computers. The connector on the PC is typically *D* shaped and contains two rows of 25 pins, about 1 ¾ inches wide. Questions for you: -Are you using that kind of cable or a USB cable? -Have you tried uninstalling and reinstalling the software following the instructions yet? Once you give us some more information we can continue.
Jan 18, 2007 | Canon CanoScan FB320P Flatbed Scanner
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Ambir Technology DocketPort 485 Logo
258 people viewed this question
Top Ambir Technology Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Ambir Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
