Question about SOLE SOURCE TECHNOLOGY Cogent Dual Iris Capture Scanner CIS 202 With Iris Capture Enrollment Software
Cogent iris scanner 202 driver
I want driver
No cd rom on laptop to download software for iriscan mouse
The driver software is not available online so here are your options:
1. contact I.R.I.S. directly, explain your situation and ask them for a downloadable version. - http://www.irislink.com/c2-2444-189/I-R-I-S--Support---Technical-Support-Contact.aspx
2. Take the CD to another computer and transfer to USB stick
3. Take the CD to another computer and email yourself the driver (could be a little large)
4. Take CD to another computer and copy to a network location
Most of these contain having access to another computer - I suggest that you contact the company directly.
Apr 09, 2014 | Iris Inc IRIScan Mouse Scanner USB
Operation error when scanning
Ensure you have the most up-to-date drivers for your i1420: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Departmental/i1420_Scanner/Support/Drivers_And_Downloads/i1400_Series_Scanner_Drivers/index.htm Looks like v3.09 is the most recent. If you are unsure of your version, download and install v3.09, if your drivers are out of date, the install will update your drivers. Test the scanner using the Scan Validation Tool (SVT). This program should be located in the Kodak folder in your start menu. SVT will test the scanner's functionality at a basic level alleviating all third party software variables. Please consult your owner's manual if you are unsure how to initiate a scan in SVT. If the 1420 scans perfectly then you need to contact IRIS for support: http://www.irislink.com/c2-2365-189/IRISPowerscan---High-Speed-Scanning-Software.aspx
Mar 24, 2014 | Kodak i1420 Pass-Through Scanner
Canon MP280 Scanner error code 5, 202, 54
I think that you haven't downloaded a driver.You'd better access the Internet to download one.(I just solve it in China this way.)
Dec 30, 2011 | Canon MP280 All-In-One InkJet Printer
Software missing can you help?
ftp://ftp02.irislink.com/support/oa/opt/support/drivers/Windows/IRISCardMini_drivers.zip
This is the Drivers for your IRISCard™ Mini.
  1. Download the drivers from: ftp://ftp02.irislink.com/support/oa/opt/support/drivers/Windows/IRISCardMini_drivers.zip
  2. Install the drivers.
Feb 17, 2011 | IRISCard Mini
I have lost the drivers of my "IRIScan" 600dpi. Where can I find them?
hi
go to below link you will get your drivers
http://www.irislink.com/c2-1741-189/Drivers.aspx
vote me if find your solution
Oct 13, 2010 | IRIScan Executive 2 Flatbed Scanner
Irispen II driver
try this link to retreive your driver for which is compatable to windows 7
http://www.driverssolve.com/sw/69135.html
Aug 01, 2010 | IRISPen II Executive Handheld Scanner
Where do I get a Windows 7 driver for the Iriscan Express 2?
The IrisScan will work with Win7 32-bit. This from both the Microsoft Compatibility Center and the manufacturer's web site. In that case, just plug in your scanner and the correct driver should load (go to Windows Update on your computer to finish the installation, if needed). However, if you need a 64-bit driver, you are currently out of luck. They only have a 64-bit XP driver (no support for Vista or Win7 in the 64-bit version.)
I hope this helps.
Dec 20, 2009 | Iriscan Express 2 Flatbed Scanner
Can not get the scanner to open, at all, no communication to the scanner. I have readiris pro 12, with an old HP OfficeJer G series scanner RP
DID YOU INSTALL THE SCANNER TWAIN DRIVERS, YOU NEED TO INSTALL IT TO SUPPORT YOUR SCANNER IRIS READIRIS PRO 10, AND WITH THE PROGRAMS INSTALL ALSO PROVIDING A CD OR DVD INSTALLER... ALSO READ THE MANUAL TO KNOW THAT YOUR SCANNER IS COMPATIBLE FIRST WITH YOUR OS or OPERATING SYSTEM, IT REQUIRES ON IT. AFTER THIS INSTRUCTION YOU MAY RUN YOU SCANNER PROPERLY... GOOD LUCK!
Jul 09, 2009 | Iris Readiris Pro 10
SOLE SOURCE TECHNOLOGY Cogent Dual Iris Capture Scanner CIS 202 With Iris Capture Enrollment Software Logo
259 people viewed this question
Top SOLE SOURCE TECHNOLOGY Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a SOLE SOURCE TECHNOLOGY Office Equipment and Supply Expert? Answer questions, earn points and help others
