Question about Garden
How do you replace a pull cord on a B&Q 40cm petrol mower
  • 1383 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
  • 376 Answers
SOURCE: i have a powerdevil petrol mower 3.5 i cannot
What is the model and type # on the ENGINE, not on the mower? Probably right above the spark plug, assuming it's a Briggs and Stratton.
  • 376 Answers
SOURCE: Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Posted on Jul 16, 2009
Lawnmower won't start.
blades blocked?
Apr 25, 2017 | Garden
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Small gas engine won't start
hi u need 3 things for a motor to run spark petrol and compression buy a new plug earth it on the side of the motor with lead on it and pull the cord to check spark///// next pull the cord with youre finger over plug hole to check for compression and last check for petrol in carby it might need a clean ......good luck. .
Sep 17, 2015 | Garden
I have Honda GV100 but there has no pull string on it . Could I take one off my old petrol lawn mower an put it on Honda ??
if you are talking just the cord it should be okay. A vid on replacing a starter cord...
https://www.youtube.com/watch?v=iczCZaRiR0Q
Aug 03, 2014 | Garden
CHAMPION VANTAGE 35 PETROL LAWN MOWER
the recoil dawgs in the cover housing are either shot or not engaging into the top starter cone
Apr 14, 2010 | Garden
Cant get my mountfield lawn mower started, it is petrol and i have primed it by pressing the pump button as per the instructions on the mower. there doesnt seem to be any resistance when i pull the start...
make sure there is a spark plug in. that would be 1 reason why there is no resistance when you pull the cord. if there is a spark plug in then check to see if there is a clunking sound when you pull the cord if this is the case then the engine has a broken conecting rod..good luck
Apr 07, 2010 | Briggs & Stratton Garden
Petrol Lawn Mower starter cord and spring problem
remove the shroud Ithe cover over the flywheel) and remove the old rope. now rewind the spring in the opposite direction of the string hole until the spring is tight. Then clamp it down so i won't unwind and reinstall a new rope (the same size) into the notch in the pully and tye a knot. then release the clamp and let the cord wind onto the pully(make sure the cord gose through the hole in the shroud. then replace the handle and reinstall the shroud back onto the engine..Good Luck
Apr 04, 2010 | Garden
I am trying to replace the cord on my mower, but the cord wont spring back in when I attempt to start it. Please help
the spring below the cord 'spool' must be wound tight before new cord is attached.disconnect cord,wind spool in the direction cord would pull it when starting until it stops & hold it there[spring is wound] release it enough to align & attach cord.release spool & allow it to wind cord onto spool.replace cover.
Oct 11, 2009 | Garden
Starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Mar 22, 2009 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
