Question about Bush 5693D 24" TV
Picture quality i turned my tv on yesterday only to find that the picture quality is blue and green on the edges of the tv
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $150 minimum to fix this particular set. Also keep in mind that if the TV is three years old or more replacement part(s) availability maybe limited.
Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jun 18, 2009
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
The screen has a blue like tint around the edges of the screen..what can i do? it's a magnavox 6p6030w101 60inch projection tv.
you have coolant in your red, green, and blue picture tubes. this coolant will start to turn dirty as time goes. the coolant should be clear but when it starts to turn, your picture has like a haze in it. coolant needs replacing. suggest local service center
Nov 08, 2009 | Televison & Video
Blue Screen
Problem with the screen driver circuitry. Possibly the blue driver is shorted or being overdriven. This may be on an IC that handles them all.
Jun 17, 2009 | Toshiba 32AF43 32" TV
Sony Trinitron picture turning green hues
Nowadays CRT's do not have good quality shadow masks anymore. After heating up a little they can give a so called "blooming" effect giving a blue an yellow leaf effect large over the screen. Reason nonparallelity in deformation of the shadow mask.
Apr 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Around edge of tv the colors blue/red/green/blurry...
my 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do anything..how much will it cost to fix this problem?kodigaston@hotmail.com
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Screen bleeding blue-green along entire length (heighth)left side
This may be some bad capacitors on the video output board or in along the processing path of the video amp sections. It is also possible that the CRT is causing this.
The set should be properly checked to determine the fault.
Jerry G.
Apr 12, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
88 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
