Question about Saws
BANDSAW BLADES I have an axminster AWSBS2 bandsaw and want to know what blades it will take, I know the blade length is 70.5 inches but searching the Axminster site is so confusing. Regards Ian
    Sergeant:
  • 468 Answers
AWSBS2 band saw takes 70 1/2" long blades. Blade Widths : 1/4", 3/8", 1/2" .
Posted on Apr 15, 2014
  • 5 Answers
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Posted on Jan 21, 2010
ToolBoxHero
  • 171 Answers
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams.  You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
Posted on Jan 06, 2011
Will a 59 1/2 inch length blade work on a 59 1/4 inch length bandsaw
Although you could probably take up the extra 1/4 inch, I would not use anything that is not recommended by the maker. They are too dangerous to muck around with. Just think if the band broke or came off its rollers, what it could do to you.
Aug 13, 2015 | Blade Saws
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
Band saw blades
Where are you located? Sawblade.com is an online blades supplier , they custom weld band saw blade to your required length.
Apr 14, 2014 | Saws
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
Shopcraft 10in. bandsaw model t676020p band legnth
Do you have the manual? It might be there but I think the blade length is about 65 inches. If you're looking for new band saw blades, you may try checking www.sawblade.com . I purchased mine with them . They have pretty good blades.
Feb 03, 2013 | Saws
Where can I get a Craftsmen 9-2664 bandsaw blade?
Quote efs_perpends
You'll need to find out the length of the blade in inches. If you have an old broken one, you can simply measure it. Then if you search online, you'll find a variety of sources that will weld/braze a custom length blade for you. (link here)
Otherwise, you might find a manual here. that gives the standard length for that machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 12, 2011 | Garden
I have been given an older bench top bandsaw make is Brico model BS 360 wouls like to know where I can get a copy of the manual for this and the blade length it requires. Thanks for the help
It takes a 70 inch blade. Don't go any wider than 3/8 inch, a 1/4 in blade works well. Get as thin a blade as possible. The 6" wheels can be ******* blades. I had new tires made for mine but have lost the name and address of the source so now I am on a search for those!
You will probably have to get the blades custom made. I get mine made at Island Saw in Victoria BC Canada. Not too expensive.
Apr 04, 2011 | Saws
Need guides for the bandsaw blade
You could try Axminster Power Tools, UK. They do a replacement set for most bandsaws.
Jan 23, 2011 | Delta BS100 Shopmaster 9 Inch Bench Top...
I need a bandsaw blade for a Craftman 3 12 ( vint. 1952 ) with a blade number 9-2664
Jun 25, 2009 | Saws
Saws Logo
204 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
