Omni avr 500w produced input but without output voltage what seems to be the problem?
  • 4 Answers
SOURCE: input/output voltage
here is a manual that may help.
http://pettersservice.com/polaroid/docs/FLM-3001ServiceManual.pdf
Posted on Jul 18, 2008
  • 165 Answers
SOURCE: condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Posted on Dec 12, 2008
  • 252 Answers
SOURCE: Honeywell F50A does not clean well
sounds like it is working. You could replace the cells and prefilters with a disposable box filter that fits.
Posted on Sep 26, 2009
  • 3 Answers
SOURCE: quest subwoofer pops every 40 seconds or without
Problem may be a blown internal amp module. Some JBL powered subs have this same problem, emiting a burst of noise from time to time even when no signal is being sent to them. I've tried fixing this problem before with only marginal success, even going so far as to install a small cooling fan inside the sub to control the overheating that can destroy these modules. If the module is blown, you can probably replace the whole sub for about what it would cost to repair it. Look into this carefully before you commit to a repair job.
Posted on Nov 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: Connecting Bose 901 series iv to Harman Kardon AVR 254
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Nov 30, 2009
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    My generac generator is producing low voltage
    check voltage input at voltage regulator, then check output from
    the regulator.
    Nov 07, 2013 | Generac 5622 GP Series GP5000 6,250 Watt...
    GENERATOR WILL RUN BUT DON'T PRODUCE ELECTRIC
    Hi and welcome to FixYa, I am Kelly.
    Without a model number... I am guessing about what type / brand and MODEL of generator you have. I have to assume it is a Coleman Power mate.
    Try flashing the field. Do this.. take and electric drill and plug into the outlets of the generator. Turn on the output power GENERATOR ON. Squeeze the drill trigger and rotate the chuck as fast as you can. This will induce voltage into the stator and they usually will start producing power. When it does produce power it will try to yank the drill chuck head out of your hand so keep that in mind.
    If the above does not work...
    Remove the small cover from the center of the endbell. It covers the end of the rotor shaft and has 2 brushes under the cover.
    INSPECT the brushes visually (do not remove them yet)
    (Generator OFF!)
    Use a meter to read resistance by probing the electrical contacts of the brushes. You MUST read LOW resistance. This is the rotor winding.
    No resistance or high resistance
    Remove the brushes inspect for damage. Try to probe the slip rings of the rotor. (You might have to make a 14/2 Romex electiral wire extension to get some solid copper wires to touch the rotor slip rings) Again you must read LOW reistance.
    If you have low resistance and the brushes are good.....
    Reinstall the brushes. (TEST for AC) Start generator
    STILL NO OUTPUT?!!!!
    Use a meter on DC to read AVR voltage output to the brushes by probing the brush terminals. You should read 3 - 7 VDC. No voltage.... hmmmm Possibly an AVR problem but...
    Try this.
    Rig up a 9 Volt battery that you TAPE the wires to the battery terminals and the case of the battery
    Just loosely connect the 2 wires to the brushes. Wrap the battery with a rag it might explode if you don't remove it fast enough. Your going to yank this off as soon as it produces power QUICKLY.
    Plug in a light or a small fan so you can see that power is being produced. Let it run a few minutes before shutting it down.
    To do anything else I need to know your generator model number to do winding and voltage regulator checks.
    Thanks for choosing FixYa,
    Kelly
    Aug 30, 2011 | Coleman Electrical Supplies
    I just bought a Denon AVR 1611. All inputs are HDMI (Cable TV, Blu-Ray) and the monitor output to the TV is HDMI. ainly I listen to the audio out of my TV and occassional on my surround sound. I would...
    avatar7.jpgcurt, I bought this Denon AVR 1611 and I have HD cable. If you have cable you can set it up two ways. First way (the way I have it) is to get a switch box with 2 HDMI
    out (mine has 4 inputs and 2 outputs) and maybe 2-4 inputs. Put the cable from the wall in one of the switch box inputs. Now hears the cool thing. Put 1 of the outputs from the switch box to the Sat/Cable input on the 1611 then put the another output to your tvs HDMI input. This allows you to switch from the tv only output or the 1611 surround output without touching the switch box. The other way is to buy a converter from HDMI to VGA. The only thing here is that you would have to setup your sound through Aux in the front of the 1611..........Johnmoondancer@hotmail.com
    Mar 06, 2011 | Audio Players & Recorders
    We just relocated our cat gen, we start it up but does not generate voltage and goes instantly to cooldown mode.
    Which model CAT???? No voltage check the AVR for exciter output first, it may be a control issue shutting down the AVR, so before replacing check for fault sensor input
    Oct 06, 2010 | Caterpillar Electrical Supplies
    Denon AVR 1601 with no sound output
    Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
    Jan 29, 2010 | Denon AVR-1601 Receiver
    Connection problem with HDMI cables on Denon AVR-589
    I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
    Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
    Feb 27, 2009 | Denon AVR588 Receiver
    No power
    Hi Jerry,
    The power wires are usually numbered 11 & 22 (one winding) and 33 & 44 (the other winding) Because it makes 190VAC on one side only I'd suspect that the AVR output got burned trying to force the rotor to make voltage it couldn't sense. If I remember correctly the AVR will have wires 11 & 22 connected to it as the sense input, so if that side of the stator is open or shorted, or if the sense wires got broken the AVR will be mased out trying to get the right voltage.
    You don't specify which model this is but some of the manuals are available here.
    Regards,
    Carl
    Jan 03, 2009 | Electrical Supplies
    Condition on HDMI input when Denon AVR-2807 switched off
    Dec 04, 2008 | Denon AVR-2807 Receiver
    Computers & Internet Logo
    David Payne
    David Payne
