I have a Westinghouse LCD 32 flat screen about 3 years old. Recently, it has began to turn it's self off. I can usually switch it back on again, but it is getting annoying. It is not powered into any other box ( TiVo , cable ) the power is all by itself going to it's on wall pull. Help!
  • digdug6 Jun 18, 2009
    Hello, The model number is LTV32W1. Thanks, Doug
  • 10,594 Answers
Symptom shows problem with either power supply board or back light inverter board that will be replaced.
Let me know exact model of TV to check power supply board availability and price info in part shops.
Thanks.
Posted on Jun 18, 2009
  • Shahid Electronics
    Shahid Electronics Jun 18, 2009
    Thanks for info,
    get back to you shortly.
    Hi again,
    Power supply board for Westinghouse LTV-32W1 is available in Shop Jimmy, please ask back light inverter board on same place as currently its out of stock.
    Thanks.
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Mar 23, 2010 | Westinghouse 32" Flat Panel LCD HDTV
The picture went black, but the tv still has audio
The back light inverter board may have gone out, or ir is not getting 24vdc from the power supply module, check those two places.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w1+
Jan 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Sep 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse 32 inch screen goes blank
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No Picture on LCD TV
The back lights can burn out, also the power supply capacitors leak and blow out. The bulb(s) are a tough fix, the capacitors are somewhat easier.
Apr 21, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
White Westinghouse 32 in Issue
Turn off the closed caption portion in the menu . The text 1-2-3 or 4 is on blanking out the center of your screen . The closed caption button could be on your remote and is being accidently pushed . Good luck
Mar 03, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
