Question about American Audio VMS4
American audio vms4 fuse - American Audio VMS4
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
Appears that the 3.5MM input jack (for my ipod) is loose/broken. How to replace it?
to do that you'd actually have to disassemble the unit. ( start by removeing scews on the bottom ) and dropping out the pc boards that hold the jack or are in the way of the pcb with the jack on it. at which you'd just have to un-solder old jack and install replacement and reassemble and your done. you cann call american audio to find distributers of their parts.
Sep 05, 2011 | American Audio CK 800 MP3 CD PLAYERS SOUND...
I bought American DJ discolights with T20f control. I do have American Audio mixer and cd player CDI 300. 2 powered Mackie 450 speakers. How can I connect the stuff?
I can only give you some ground rules to follow: Connect ALL of the audio equipment to a single receptacle or power conditioner. This may mean running an extension cord back from where the speakers plug in to the mixer. Use BALANCED lines, either XLR or TRS to connect the speakers to the mixer. Power the lights separately. To give anymore suggestions would require a diagram of how your venue is laid out and the location of power, etc.
May 10, 2011 | American DJ T20f Chase Control Pack W/foot...
The Crossfader does not work. I just bought it. I don't think it's broken even though everything else works.
Exactly the same thing happened to me think they send them out like it so you get the info fader upgrade I took out the two screws popped the fader out it was cruded up so I sprayed contact cleaner in to it.Just to clarify you have it set up right if your using it just with software you need the in on chan 2 out on chan 3 on the front and make sure the curve is set right
Mar 28, 2011 | American DJ VMS4 Digital DJ Work Station
Fuse blew out on my american audio after my girlfriend tripped on the chords, how do i repair it . is there a fuse or a reset button thank you
You are saying the fuse blew out and then asking if there is a fuse??? That makes no sense...
Tripping on cords could do certain things but NOT likely to blow a fuse.
Tripping on cords OFTEN breaks the plugs on the cords or the jacks in the equipment. The power input jacks from those wall transformer power supplies seem to be very vulnerable to this. They often disintegrate OR break loose from the solder on the circuit boards rendering the unit inoperable.
In future, loop the cords through handles so they don't yank the jacks if somebody yanks the cord.
Dec 26, 2010 | American Audio CK 800 MP3 CD PLAYERS SOUND...
My vmx1000 mixer the crossfader only cuts out one side the other just contiues to play no matter what side u put it on
I suspect that one element of the crossfader pot (slider) is broken. Possible cause is if something fell on the knob or wear from use.
If one end breaks on one channel, the opposite end side will remain on full while the other channel will behave normally.
Replacement of the dual pot will LIKELY involve removing all panel knobs to remove the circuit board to replace the pot after disassembly of the unit. Not for the casual DIY person.
Nov 17, 2010 | Behringer Pro Mixer VMX1000USB...
Were can i find instructions to make clay animals?!?
Here is a website that describes how to make clay animals.
PLEASE CLICK HERE
I hope this helps and Good Luck.
Nov 11, 2009 | American Audio Music
KORG EA-1 MK 11 ELECTRIBE OWNERS MANUAL
Thanks For Using Fixya A Direct Download Is Here.
Enjoy And Thanks Again.
Sincerely,
Michael Scott
Feb 16, 2009 | American Audio Music
American Audio VMS4 Logo
Top American Audio Music Experts
Vito Vacirca Jr.
Are you an American Audio Music Expert? Answer questions, earn points and help others
