Question about Dishwashers
Bosch dishwasher check water light
Check water light stays on and cycle does not want to end, although the appliance is empty. it even seems to keep running if i open the door.
  • 1462 Answers
SOURCE: Dishwasher seems to be doing everything except washing
what your friend did would not affect the appliance. by the sound of it the main circulating pump or pump capacitor is faulty. capacitor is a cheap part but the pump will be expensive. only way to find out is to dive in and look. is pump motor is faulty then this will be faily obvious - burnt winding. if no apparant motor damage try substituting the motor capacitor - this is a cheap part
Posted on May 23, 2007
SOURCE: dishwasher not running
just got this, and have same prob, i have run through all checks
Posted on Jan 29, 2008
kachbibi1
  • 979 Answers
SOURCE: Dishwasher motor runs (even with door open), but no Water
I believe the problem is in the electronic board. It is getting a different signal thus not allowing it to run properly. You can have a local service technician for the company look at it but this is probably the cause.
Posted on Dec 25, 2008
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
  • 44 Answers
SOURCE: Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Posted on Mar 29, 2010
Bosch SL1501B dishwasher doesn't drain water after the washing cycle. Also with new drain pump. What else could it be?
Check the following.
1. The drain hose has to be discharging at a high enough point to prevent water flowing back into the machine.
2. Make sure your drain hose is not twisted or kinked.
3 . Make sure your drain line is not blocked push a flexible hose down it to dislodge any fat/debris
4.If your drain line discharges into a shared drain with another appliance i.e. garbage disposal make sure it is not blocked.
5. You may have a blockage at the inlet to the pump which would slow down the pumping rate,
Since you mentioned the mushroom shaped float allowing the washer to empty this may be defective.
See the link attached.
Hope this helps.
Crofter
Bosch Dishwasher Does Not Drain
Apr 30, 2015 | Bosch Dishwashers
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
Mar 29, 2010 | Bosch Dishwashers
My bosch excel dishwasher has the following fault: start the cycle, water starts to fill but then check water light comes on and it then starts to empty again. Pump then keeps going. I have checked the...
this unit im sure has a water flowmeter that measures the water intake.. if this cannot read then the unit shuts down to avoid flooding..
it needs replacing... it is attached between the valve and the side tank or attached to the tank dependant on model...thanks
Dec 18, 2009 | Bosch Dishwashers
Dishwasher not emptying at the end of its cycle. If water siphoned out will work temporarily then fails again, with water remaining standing inside machine. Check water indicator light is on, goes off when...
Not sure of your light indicator; check the manual. But fyi there should be a little water left in, so the rubber seal doesn't dry out. More than that, and could be clogged drain or bad solenoid, which tells it to open and drain. See: http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Sep 17, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
May 28, 2009 | Bosch SHU3036UC Dishwasher
Water not draining from my bosch dishwasher
there will be something jamming up the drain pump empty the water out of the appliance if you study your operating instructions there will be an intsruction in it as to how to remove the drain pump cover and clear the impellor be carefull ill bet is a piece of glass
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Bosch dishwasher still some soap left on dishes
Most of the causes of the problem that you are describing are related to the way the dishes are loaded in the unit. To test this, run it empty and see if the dish soap dissipates.
Mar 17, 2017 | Bosch SHU3305 Dishwasher
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
