Question about Hotpoint-Ariston SDL510P Dishwasher
Do I remove the polystyrene from the back of the dishwasher?
Brand new and taking this out of the packaging. There are some polystyrene blocks in the back of the dishwasher. Looks like these can only be removed by screwing off the back. Do these need removing?
After the Polish workmen half installed my dishwasher, I noticed that the sides flapped about.
My partner has her own Ariston dishwasher. It had to be taken out to redo the work of the Polish Heating Engineer.
I noticed that it had a polystyrene piece running across the back of the machine. There was a sign on it saying - "Do not remove". The Polish workmen who had installed my machine had removed it.
Posted on Jun 13, 2014
3 Suggested Answers
  • 539 Answers
SOURCE: can't remove polysterene hotpoint diswasher
Go to www.manualowl.com for the free PDF of your owner's manual and then go to the Index of PDF for the troubleshooting section. Perhaps you can put an end to your vexxing problem with your dishwasher. Best of luck to you, Evelyne. Jimmy
Posted on Apr 11, 2012
  • 539 Answers
SOURCE: Polystyrene door
Go to www.manualowl.com for free PDF and see if you can locate your owner's manual there. Then look up the Index in the PDF for Troubleshooting your issue. Hope this helps to end your very frustrating problem with your dishwaher. Best to you. Jimmy
Got a new samsung dishwasher is dripping water on the both bottom sides of dishwasher. I may need the rubbers in the inside fix them some how. not sure
there is a rubber on the inside at the bottom this may still have the plastic on it check this. there are a few other places that the plastic could be aswell so have a good look round. sometimes even the packaging can get stuck in them from being moved around in delivery throws polystyrene balls.
Oct 25, 2013 | Samsung DMR77LHS Tall Tub Dishwasher
Asko 20.1 won't stop pumping unless I turn it off at the wall switch.
this happened to my D3111 and, sure enough, there was a split in the water outlet hose and the water overflow raised the polystyrene float block.
6 months later th same symptoms occurred but the inner base was dry. I took off the lower front panel under the door and found the water level (3 terminal) microswitch had burnt out, probably from running too long. Easy to replace if you can hunt down the $2 switch (brand name Zippy, 6 AMP)
Nov 16, 2012 | Dishwashers
Polystyrene door
Apr 11, 2012 | Hotpoint-Ariston FDF784K Dishwasher
Can't remove polysterene hotpoint diswasher
Apr 11, 2012 | Hotpoint-Ariston FDF748P Dishwasher
Hotpoint fdw60 , were is the float switch?
The float switch is screwed to the bottom panel.  If you tip the machine onto its side, you will see a metal panel held on with six screws - 3 at the front - three at the back.  Remove these screws and remove the panel.  The float switch is secured to the back of this panel. It is a white polystyrene block suspended below an electrical switch.
Feb 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher won't drain
Check that you have removed all the packaging pieces from the unit, If this still doesn't work then return it to the store and get a replacement.
Thanks J
Feb 16, 2008 | Beko 24 in. D3421F Free-standing...
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Apr 21, 2007 | Smeg DWI614 Built-in Dishwasher
Hotpoint-Ariston SDL510P Dishwasher Logo
1,262 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Antonio Santacruz
Antonio Santacruz
Kelley Jones
Kelley Jones
Level 1 Expert
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
