SOURCE: 2007 GMC YUKON denali, rear brakes have an air
Here's a link to a thorough article on the subject which should help you...
http://www.aa1car.com/library/abs_bleeding.htm
SOURCE: will a repair manual explain to me how to fix a brake booster?
Yes , for sure. A haynes manual is a must have for anyone who wants to do work on their own car. It will save you hours of frustration and unnecessary work. WELL worth the cost.
When you say the booster is going out , are you sure ?
They work of a vacumme hose from the engine , if that hose is leaking , or the little valve where it goes into the booster is no good , than you might think the booster is bad when it is good.
In general terms either the booster is good , or it is bad and you have to stand on the pedal to get any brakes.
If you post more info about what your brakes are doing , or not doing , someone might give you a different solution / diagnosis.
SOURCE: why do I have brake
The master cylinder seal is bad. (seal between master cylinder & booster) Common GM problem as they age.
