Question about Kitchen Ranges
My AEG oven is cutting out if put on over 170/180 degrees.
  • 132 Answers
THERE IS ATHERMISTOR ELEMENT HAS TO FOLLOW THIS
MAY BE IT HAS COATED BY INSULATION MATERIALS FROM FOOD . AFTER YOU CHECK THAT USE THE RANGE AGAIN
IF THE PROBLEM PERSIST CHANGE THIS ELEMENT BY THE SAME PART NUMBER .
THANKS
Posted on Jun 18, 2009
My AEG B3101-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
It is a safety thermostat that is cutting the oven off, due to overheating.
It could be that the external cooling fan is not working, or the cut out itself is faulty.
Check to see if you can hear the fan working.
This is usually located on the top of the oven , at the rear of the oven, on the top .
Hope this helps.
Dec 13, 2009 | AEG B3101-4 Electric Single Oven
Aeg oven d4100 cutting out
There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
Dec 07, 2009 | AEG D2100-4 Electric Double Oven
I have an AEG B6139 electric oven and the interior light and fan comes on but the oven will not heat up despite putting the setting on high. Next to the dial for the interior light and fan a small red...
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
Apr 29, 2009 | AEG B3101-4 Electric Single Oven
Oven gets too hot AEG B3101-4
Hi I am Vortash This sound like the thermostat cut out switch and if it is glowing hot then you have a serious DANGEROUS fault
it means that it is not disconnecting as it should and has shorted ot .. please get it changed immdeatly as it may short to the oven body causing it to become live .. now that should mean that the house fuse should blow .. but on the slight chance it don't you would be electrocuted if you touched the oven please call a domestic service engineer now Regards Vortash
Apr 13, 2009 | AEG B3101-4 Electric Single Oven
Oven cuts out
Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
Nov 30, 2008 | Ovens
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
