Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
I can get no response from my oven....all there is is the letter A showing on the display. Sa 392 eb
2 Suggested Answers
BADBOYJAY
  • 264 Answers
SOURCE: Oven won't work
as you look at the clock A means automatic you want to hold in the Manuel button it looks like a hand and hold in the + that will then let you cook that's it before you do this turn oven off and back on then do as i said ok. good luck
Posted on Jan 07, 2008
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
Changing from C to F temperature on Gaggenau EB
your oven has no ability to change from celcius to fahrenheit here is the link to the manual:
http://www.gaggenau.com/AP_en/products/product-detail.do?contentId=cc4fb38a-ea89-4593-a268-95ea093f9d3f
there might be a secret mode but only the manufacturer might know that.
all dealers are in other countries.
Sorry I could not resolve this issue for you.
Feb 14, 2010 | Gaggenau Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Gaggenau eb 270
No you don't need to remove the oven door to change the cover of the display. You have to remove the whole unit out and remove the top lid. Don't forget to switch off the circuit breaker before doing this and be careful this unit is heavy.
Jul 02, 2008 | Gaggenau EB 270/271 Electric Single Oven
Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Mar 05, 2008 | Ovens
Oven won't work
Jan 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
