Question about Junkers Watches
How to replace the battery
I would like to know how to open the junkers G38 (6296-02 model) in order to replace the battery
What size battery does Tommy bahama RLX3005 watch require?
1.800.677.8278 All I can find is a phone number. Hope this helps.
Aug 09, 2014 | Tommy Bahama Watches
Battery indicator issue
Although your watch is solar-power all Eco-Drive watches contain a rechargeable battery known as a capacitor. They last longer than a regular battery but are difficult to get replaced because nobody carries them. Firstly I assure you whoever opened the watch did damage it. The solar sell is under the dial so removing the back would not have exposed it to anything. Rechargeable batteries do not hold a charge forever and do need to be replaced every 5-10 years. In order to know which capacitor you need you need to find out what movement model is in the watch (this is different than the model number of the watch you must physically look at the movement) (unlike batteries capacitors all have the same number on the cell so you need to know the movement number to order the proper size). Once you have obtained the capacitor repairing your watch because no more difficult then changing a battery. I'd ask those people to take the back off again so you can find out what movement is in the watch. Typically it's a 4 digit number but sometimes it also has letters in front of it and I've also seen them with only 3 digits. If you could supply me with the movement number I can supply you with a the proper capacitor at a price of $45 with free shipping and tracking.
Dec 26, 2013 | Citizen Skyhawk A-T Watch for Men
I cannot find a battery replacement for my Kenneth Cole watch KC4584. It says on the back, C275-07 for the battery.
I do not believe that is a battery model that I have ever heard of . The best thing to do is to open the case and take out the battery , it should state the model number on the actual battery. If you have a hard time after that please let me know and I can help you out further but the c275 is not a watch battery model number.
Oct 17, 2010 | Kenneth Cole Watches
I took my timex wr30 into have the battery replaced and back was damaged I need to know where I can order a new one
only from timex they need model and serial number of case back or and shop that sells timex will be able to order case back or any good repairer.
Mar 23, 2010 | Timex 27191 Wristwatch
I dont have an instruction manual for my junkers 6296-2
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
Mar 09, 2010 | Junkers Watches
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Fossil Fs 4296
Yes, your watch definetely needs a new battery. Find your nearest watch repair shop and ask to replace battery. Your watch will tick as brand new.:))
Jan 08, 2009 | Fossil Rectangle Silver FS4296 Watch for...
Softwatch by Exaequo
call 973 444 7400 solve all watch &parts problems
Mar 20, 2008 | Watches
Watches Logo
Top Junkers Watches Experts
Jimmy Accardi
Are you a Junkers Watch Expert? Answer questions, earn points and help others
