Question about Behringer XENYX 5-Input Mixer 302USB
Static noise when headphones are plugged in and there is no inputs or outputs
  • Behringer Master
  • 3,382 Answers
Unless the levels are turned down I would expect that. It probably is what is called pop-corn noise. Turn the levels down it should disappear.
Posted on Oct 23, 2014
Why cant i get sound from wireless headphones when plugged into rca input
Looks to me like you answered your own question. INput is for INcoming signals (microphone...). OUTput is for OUTgoing signals (headphone, speakers...) Looks to me like you answered your own question. INput is for INcoming signals (microphone...). OUTput is for OUTgoing signals (headphone, speakers...)
May 23, 2016 | RCA Televison & Video
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Hi, I have JVC CA FSY! and it has static noise on speakers but its ok on headphone. How can I solve this problem?
http://books.jvc.com/booklist.asp?Model=fsy1
Choose your submodel.
So the good news is that the amp isn't implicated but an electrical conductor somewhere in the path may be flaky.
Headphone insertion mechanically disconnects output to the speakers. Hence, headphone removal relies on spring-loaded contacts to restore the output to the speakers. Perhaps there is oxidation on the normally-closed contacs. Repeated headphone insertion/removal MAY help wear it off.
Also try swapping the speakers (wire and all) to see if the static follows or stays with the amp channel.
Jul 12, 2011 | JVC FS-Y1 Theater System
Im getting a wierd sound when i unplug my headphones what do i do
Open up your computer the speakers plug/outlet and the headphone plug is usually at the back of the computer
to check the lead attached to the rear of the input plugs make sure the connections are good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 19, 2011 | Dell Audio Players & Recorders
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
Analog Audio Out signal has very high distortion. Signal wanes in and out, wanders from one channel to another, and develops high static. This happens when Audio Out is configured for Fixed Output. When...
The problem is more likely to be with the wireless headphone set rather than the TV. It makes no sense that the signal changes channels. The only difference betweent he fixed and variable output is whether or not the volume changes the output signal amplitude. The channel selection process is not handled there. The distortion is likely due to the input of the wireless being overdriven. If available, turn down the input gain on the wireless and try again. Please update this with the results.
Thanks,
Dan
Feb 28, 2011 | Televison & Video
Static noise in headphones over music
well dumby all you got to do is get some new headphones, it's like 10$ stupid
Jun 01, 2010 | AKG K 206 Consumer Headphones
White noise in left channel on my Vestax PMC 06 pro-a DJ mixer
try it with nothing plugged in to the inputs, if there is no noise. most likely its the turntable, cd player, or whatever the input is is the problem. or try plugging the mixer into a different area of the house/room. its like if you were to put your cell phone by a mixer, or speakers.
Jun 25, 2009 | Vestax Pmc07pro DJ Mixer System
HAVE NEW SET OF hEAD pHONE CANNOT PULL A SIGNAL IN STATIC THERE BUT FAINT...
Make sure you are connecting to the OUTPUT section and not the input, look in the back of the television it should say output and have its own red and white pluga, if you connect the red and white cables to the input section on the front of the television or on the section on the back that says input you will not get any reception make sure you are connecting to the output
Dec 26, 2007 | Sennheiser RS 110 Consumer Headphones
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
Behringer XENYX 5-Input Mixer 302USB Logo
143 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
