Question about Garden
Ryobi rct 2800 e
There seems to be a problem with the flow of fuel to my RCT2800, the primer bulb doesn't fill with fuel. I have cleaned the pipes and when not connected to the fuel does flow from the tank but the bulb isn,t pushing fuel through to the carbureter
    Scholar:
    New Friend:
  • 119 Answers
Could be a few things
air leak in your fuel tank
air leak in your pipe
even your zama carburetor
all can be obtained on ebay
Posted on Apr 14, 2014
  • 376 Answers
SOURCE: Gas does not go through the primer bulb
Unless you had the fuel lines off or replaced them, leave them where they are. The problem most likely is in your carb. The diaphragms are possibly brittle or the needle is stuck from varnish from old gas. The easiest solution is to replace the carb.
Posted on Jun 27, 2009
worldvet
  • 859 Answers
SOURCE: Ryobi Grass Scorpion Petrol lines from tank to primer to carby where to where
Thanks to doityourself.com.
The line off the top of the primer bulb goes to the top of the carburetor.
The line on the bottom of the primer bulb goes to the fitting on the center of the fuel tank and the line off the side of the fuel tank goes to the bottom of the carburetor.
Regards,
Worldvet
Posted on Oct 28, 2008
  • 199 Answers
SOURCE: primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Posted on Jun 10, 2009
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
canbruce75
  • 1776 Answers
SOURCE: Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Posted on Jul 11, 2009
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to hook up fuel lines on a ryobi 08576 backpack leaf blower
hook one up and press the primer bulb if it doesn't squirt fuel out when the bulb is pressed you have the wrong pipe connected
primers work like this they suck fuel from the tank , through the diaphragm pump , into the float diaphragm and out back to the tank
Nov 17, 2017 | Ryobi Garden
RY28100 primer bulb does not fill. New bulb, new fuel lines & filter, plus carb newly rebuilt. Still doesn't fill bulb or start!
Does it have a base to the primer which sits on the carb.? Have you connected the pipes correctly.??
May 19, 2016 | Ryobi Garden
Need to know how and where the fuel lines connect on a Ryobi Sweeper vac RSV 1100
If your machine has a primer bulb then this is the sequence.
Fuel pipe from the tank, with the filter on. Goes to the FUEL IN side of the carb.
The suction side of the primer then goes to the FUEL OUT side of the carb.
The Primer 'blow' side then goes to the return to tank pipe.
To know which side the 'Suck' and 'Blow' side of the primer are, simply depress the primer and place a finger over one of the outlets to determine the order.
May 17, 2016 | Ryobi Garden
I have a problem with my ryobi rlt30ces its seems to be sum kind of fuel blockage it ticks over then dies checked spark plug ok cleaned out carb im mystified
Put a new primer button on it the old primer diagram is old and has gotten tough less flexible and will stick and cause a kind of back pressure that will not allow the fuel to flow. Had this kind of problem on my stilh.
Aug 08, 2012 | Ryobi Garden
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Hello, I have an Echo SRM-3100 weed wacker 2-cycle that i can start but can't get it to run. i checked the fuel lines and they are clear, i took apart the carb and eveything is clean and in good...
Just to clarify, the purge bulbs actual purpose is to purge the carburetor of air and old fuel and help to pull fresh fuel from the tank to the carburetor. Some units have a purge bulb located on the carb and some have the bulb remotely mounted. I think on your model, the bulb is atop the carburetor on the primer base assembly. If the bub doesn't release, then there possibly is a problem in the fuel tank fuel cap vent. Check the cap and make sure the little duckbill vent is clean and clear. A vapor lock type situation can develop when atmospheric pressured air can't enter the fuel tank. You may also want to remove the purge bulb cover and the bulb and spray the top of the primer base with WD-40. You can remove the fuel lines and spray some into the carb as well. This will maybe clean and lubricate the sensitive check valves that may be sticking in the carburetor, causing your problem. Try this more than once if it doesn't seem to help at first. Internal check valves control fuel flow in and out of the carburetor and they do occasionally malfunction.
May 15, 2011 | Garden
My Ryobi start great but when I change it from start to run stays few seconds and died
  • Alow the engine to run for longer on the start setting before you switch to run
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run.
Apr 05, 2011 | Ryobi Gas Hedge Trimmer
Ryobi Leaf Blower
yes,,,,its a dirty carb jet or a blocked carb jet strip the carb and blow out all the running jets,dont go poking wire into any of the jets to clean them this could bistroy the jet/s
May 08, 2010 | Ryobi Snap In Primer Bulb Pump 683974 ...
Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
