Question about Hotpoint Washing Machines
Water wont pump out code f-05
Hi my washing machine has stopped working it fills up and spins but then it stop and the water doesnt pump out and the code f-05 flashes! can anyone tell me if i can fix this please
    Habit-Forming:
    New Friend:
  • 86 Answers
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Posted on Jun 19, 2014
  • 16 Answers
SOURCE: My washing machine doesnt stop filling the tub when the right water level is reached
Not familiar with this model. When a washing machine fills with water up to a predetermined level, it usually operates a pressure switch which will turn off the water valve, and redirect the power to the programmer, or heater, or some other stage of the programme. If there is a blockage of powder or gunge in the tube leading to the pressure switch this would prevent air from rising up the tube to operate the switch. Tom.
Posted on Mar 09, 2007
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
SOURCE: washing machine wont fill
It could be a bad water valve or it could be the board that controles the valve, I would check first and make sure that the two water hoses where they connect to the washer are not limed up or have some build up of some kind, you can turn the water off and disconect at the washer and visualy ck to see.
Posted on May 10, 2007
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
Hi my beka 1400 wont wash water comes in for a few second and then stops its rinsing ok
beko take water in for few seconds then switch to test pump.....if alls well....then it restarts again...if yours doesnt........check the pump first... if it fills with water then stops.......check motor brushes .........
cheers
Nov 22, 2016 | Washing Machines
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
I am not sure what that fault code means but you should be able to find the codes on the Internet.
I would suspect that the problem is a jammed or blocked or faulty drain pump. As has been sugested drain by gravity by lowering the hose into a bowl to the floor, -----REMOVE THE PLUG FROM THE SOCKET. ---- Inspect the pump, see if it is blocked or jammed, the hoses come off quite easily. Clear any rubbish out and see if the pump will then run by selecting pump and spin cycle when plugged in.
It is a good idea to take the thin pressure switch hose off at the switch end and make sure that it is clear through to the bottom by blowing down it. Make sure the machine is unplugged first.
Gently blow the switch too, you must get 2 clicks , first one with a gentle blow, and another with a slight increace in pressure.. Refit all hoses securely.
Hope that will solve your problem.. Sam.
Apr 14, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
I have FAFW3574k- Fills w/ water. Starts to run cycle but then wont spin. Pump sounds like its running but water doesnt come out. Thanks Jeromy
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2011 | Frigidaire Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
heatman101
Apr 21, 2011 | GE Washing Machines
It fills up with water then stops, it does spin but doesnt agitate
Hi just read your posting.Now can you please reply with the model number of your machine and also after it stops filling does it stop and beeps and shows an error code?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 28, 2010 | Fisher and Paykel Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
