About motherboard my computer's motherboard(amd 64)was fused.does moather board have warranty , how many years
  • 334 Answers
Should have one year. what exactly is fused?
Posted on Jun 18, 2009
How Do I unlock CPU cores with Bios on MCP61M-M3 motherboard?
The motherboard supports AMD socket AM2 single-core Athlon 64/ Sempron and dual-core Athlon 64 X2/ Athlon 64 FX processors with 2MB / 1MB / 512KB L2 cache, which is based on 64-bit architecture. It features 2000 / 1600 MT/s Hyper Transport Bus, dual-channel un-buffered DDR2 800 memory support and AMD Cool 'n' Quiet! Technology.
The BIOS changes it on it's own when add a dual core.
Here is the PDF file on this board. Chapter 2 explains the Bios.
Jul 03, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
I am using ASUS K8VMX motherboard with AMD Athlon 64 2800+ motherboard. Now my motherboard has gone bad. I want to change it. Suggest which motherboard should i use (754 socket)
Whatever board that is in a microATX format and has a 754 socket will do - they all had the same general hardware characteristics and requirements - so get the cheapest you can find.
Apr 17, 2011 | AMD Athlon-64 2800 CPU and Mother Board...
Sir , i found my mother board is good . but , my processor failed to boot mine is AMD ANTHLON 64 3500+ . I dont have even a small damage to the pins in the processor , everything is good. my processor...
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.
You will not find replacement parts, you will need a new system.
Feb 13, 2011 | AMD Athlon64 2800+, 1.8 GHz Athlon 64...
Can the gigabyte ga-ma74gms-2h motherboard support any of the new icore cpu's
For what I have read on this MOBO, it is AMD processor only board so it will not support Intel in any way. Below is the list of processors the board supports....alll AMD
Athlon 64 X2 , Sempron , Phenom , Phenom X3 , Athlon 64 , Phenom X4 , Athlon 64 FX
Aug 01, 2010 | Gigabyte Computers & Internet
AMD 64
sound;s like a connection problem unplug to reset then try it again ok;
May 01, 2010 | MSI K8NGM2-L Motherboard
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
Mother board - amd to be repaired
If it was under 3 years
then AMD- Asus / Gigabyte /MSI motherboards comes under warranty of three years.
Whats the brand of the Motherboard Asus / Gigabyte?
(when u switch on the PC on right side of the Screen u can read the name of the Manufacturer)
Asus Service Centre is at lamington Road, Mumbai
Gigabyte Service Centre at Kalina, Mumbai
You can approach Service center for the particular Vendor and get the board repaired. (As it is out of warranty, otherwise you cud have got the replacement)
However, they will take approximately 8 days time. :(
Dec 29, 2008 | Computers & Internet
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
