Question about Fisher and Paykel Cooktops
Removing light scratches from glass cooktop - Fisher and Paykel Cooktops
4 Suggested Answers
  • 222 Answers
SOURCE: Scratched cooktop
as far as i know its normal to have an scratched in glass ceramic hob defend how long to use or many times of use.do u think is same usage? its normal defend on usage.
Posted on Jun 23, 2009
  • 106 Answers
SOURCE: I was cooking popcorn on my glass cooktop and the
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Posted on Oct 30, 2009
Testimonial: "thanks so much...it won't happen again."
  • 34 Answers
SOURCE: I need to replace the glass cooktop. Can anyone
you have to call the company who it was manifactured out of sorry
Posted on Jan 14, 2010
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
I have scratches on the edge of the oven in front
Use 3m Scotch brite #7447 or 220 grit sand paper depending on the severity of scratch. Always finish any sanding by blending with the #7447 pad. Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 27, 2010 | Thermador PSC364GDZS Gas Cooktop
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Scratched cooktop
Jun 20, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Porcelain grate scratched or stained?
If you keep using the range without the aluminum pans it will eventually go away, but aluminum will leave marks on the surface of the grate.
Aug 20, 2017 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Ge cooktop burner does not get heated but hot sensor light goeson
common for the glass top have a scratch,coz this a glass it normal for every time u use coz the metal for the pots & pans are sharp for the glass.tnx gerbee
Jan 26, 2009 | Cooktops
Melted plastic (teapot whistle) on glass cooktop
Hello. I don't know if this will work but you could try getting it as cold as you can and maybe it will come off that way. If it were me I would use my refrigerant, but I am sure you don't have that. Who knows maybe ice will work. Now that I think about it, maybe you can carefully use some sand paper being sure you don't scratch the surface.
Nov 28, 2008 | Jenn-Air JED8430 Electric Cooktop
Cleaning glass cooktop surface
I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Scratch Removal
I remeved the scratches on mine with a 600 gritt sand paper, but you have to do it wet, wet the sand paper and keep it wet, it takes a lot of sanding but it workd and do not show marks
Hope this help
Eddie Rentas
Tupper Lake
Jul 15, 2008 | Cooktops
Cooktops Logo
65 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
