Question about Hotpoint Aquarius WMA42 Front Load Washer
Water wont pump out code f-05
Hi my washing machine has stopped working properly it will go on and spin and fill with water but then it stops and it doesnt seem to be pumping the water out and then a code flashes up F-05 can anyone tell me what this means and how to fix it please?
  • Ian thompson
    Ian thompson Apr 14, 2014
    Hello, I think you pump filter is blocked. It's around the back of your machine, it's abit tricky mind.
    New Friend:
  • 15 Answers
I am not sure what that fault code means but you should be able to find the codes on the Internet.
I would suspect that the problem is a jammed or blocked or faulty drain pump. As has been sugested drain by gravity by lowering the hose into a bowl to the floor, -----REMOVE THE PLUG FROM THE SOCKET. ---- Inspect the pump, see if it is blocked or jammed, the hoses come off quite easily. Clear any rubbish out and see if the pump will then run by selecting pump and spin cycle when plugged in.
It is a good idea to take the thin pressure switch hose off at the switch end and make sure that it is clear through to the bottom by blowing down it. Make sure the machine is unplugged first.
Gently blow the switch too, you must get 2 clicks , first one with a gentle blow, and another with a slight increace in pressure.. Refit all hoses securely.
Hope that will solve your problem.. Sam.
Posted on Apr 14, 2014
SOURCE: fills washes rinses but wont spin properly or empty out
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Posted on Oct 19, 2007
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
barkencoa
  • 3463 Answers
SOURCE: cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Posted on Jun 21, 2009
  • 197 Answers
SOURCE: Hi I have a hotpoint washing machine model wt761
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Posted on Oct 25, 2009
Wont stop filling
The fill solenoid is stuck in the open position. Replace it for proper operation. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Amana Washing Machines
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Clogged drain pump.
Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
If not, replace drainpump
Apr 14, 2014 | Hotpoint Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
