Question about Hotpoint Washing Machines
Water wont pump out
Hi all of a sudden my washing mashine has stopped pumping the water out it will spin and fill with water and then it will flash up f-05 and all the lights flash can you help?
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
Clean the filter
Posted on Apr 21, 2014
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
  • 30 Answers
SOURCE: Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Posted on Mar 14, 2008
  • 72 Answers
SOURCE: washing machine wont spin
Maybe something is physically preventing the drum from spinning, causing the motor protection to kick in and stopping the machine.
I'd check this out as a first step before calling a repair man:
1) unplug the machine from mains
2) make room between the rubber gasket and the drum for your hand/arm to reach down into the bowels of the machine, in the compartment between the drum and the bowl (or whatever you call it). If you find something strange there, remove it.
I've done this on occasion and have found lots of obstructing objects that don't belong there. Most notably hardware from underwire bras I might add... :)
It is worth a try.
Posted on May 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: hotpoint Aquarius+ WF740 washing mashine flashing F-05s
  • F05 - Pressure switch jammed on full
  • The pressure switch must be changed.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 15, 2010
    • 7 Answers
    SOURCE: older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
    check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
    Posted on Mar 01, 2013
    Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
    The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
    Jun 03, 2015 | Washing Machines
    Mashine fills with water
    check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
    Mar 24, 2015 | Washing Machines
    Water wont pump out code f-05
    Clogged drain pump.
    Check the drain pump filter. Use a flashligth and you will se if the impeller is stuck on something. If not check the hose from the drum to the drainpump housing. May be clogged.
    If not, replace drainpump
    Apr 14, 2014 | Hotpoint Washing Machines
    Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
    That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
    Jan 01, 2011 | LG Washing Machines
    It will wash but water will knot spin out
    Hi is the mashin spin but the water not out?
    check the water pump maybe some thintk in it
    Oct 27, 2010 | Washing Machines
    Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
    Hello Paula,
    Do not know how many flashes but 1green/1red = 11 water pressure low.
    2green/1red = 21 blocked filter or pump fault.
    You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
    Hope I was of some help.
    Good Luck
    Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
    My washing mashine wont spin or drain
    hi there,
    it sounds like the drain is blocked, check the drain access at the front
    for any debris/or coins that may have been left in the pockets of garments, have a good rake around and use a torch, the machine will not spin without pumping out the surplus water so there lies your problem blocked tubes or a faulty water pump.
    Feb 15, 2010 | Indesit W 123 Front Load Washer
    Washer will fill fill with water but doesn't start wash cycle
    it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
    Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Avanti W797: Tub won't spin or water does not empty.
    Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
    Nov 20, 2007 | Avanti Top Load Washer W797
    Washing Machines Logo
    60 people viewed this question
    Top Hotpoint Washing Machines Experts
    puggy666
    Level 1 Expert
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
