Question about Flat Panel Televisions
Tv went black
Model # z42px2d by zeineth.
Re: tv went black
I've owned this unit since Dec 2005. It appears there are two Video Amp boards Z & Y-SUS boards, that have failure problems.
After 10 months, my ZSUS board went out and was replaced under warranty. And... Just a month ago, the same problem occured again, so I've complained to Zenith (LG) and they are extending my warranty to repair the unit.
Posted on Dec 09, 2007
0 characters
3 Points
Zenith Z42PX2D Plasma tv
Something short circuit with its circuit board. you must have through knowledge in electronics, and work experience to do repair work to this Plasma TV. As you know, plasma TVs are the latest technology devices, and a mere knowledge in electronics will not help. It will be best to get this set repaired by any experienced service technician or by the authorized service center for Zenith at your town. [Short circuit protection circuit energized, and latched the relay, not to supply voltage to damaged circuit board is the problem] The click sound you heard was the latch sound of the protection relay.
Aug 14, 2012 | Zenith Flat Panel Televisions
There is a four inch black line on one side of the screen
I think your problem maybe picture tube.
next try
At first test for you flyback transformer and A.C. transformer out put voltage.
Best get it checked at your local repair shop.
Send report
Jul 27, 2011 | Zenith Z42PX2D Television
My 42" Zenith plasma flat panel television model
You can check the va, vs adjustment, but alot of plasmas does this, my first thought would be the y sus board, it also could be the panel which is not worth fixing, if it is really bad, check voltage and if this isn't out then Y- board is the next thing to check.
Jan 27, 2011 | Zenith P42W24B 42 in. Plasma Television
a lot of those get a bad Y board or panel driver. sometimes both.
Apr 08, 2010 | Zenith Z42PX2D Television
Zenith Plasma TV, Model: Z42PX2D....Menu Buttons on TV had no effect. What could be the problem?
The problem is from the menu control board inside the TV. A Ic or transistor might be faulty on the board.
Take care.
Mar 11, 2010 | Zenith Z42PX2D Television
Techwood HDMI 32'' TV - Went to black screen while watching
Am Tv same model did the same thing this mornign while i played FIFA 2010 world cup on PS3 Fat...what could be the problem???
Jun 14, 2009 | Flat Panel Televisions
I know it's rather late to post this but just thought I'd post anyway, maybe you still need the help. If you get no sound and no picture but yet an amber light (yellow) also if you heard a pop sound from one of the fuses, there is a good chance that you YSUS board has take a turn for the worst. There are kits that you can purchase for $200+/- that will get you back up and going....for 5 more years.
Sep 11, 2008 | Zenith Z42PX2D Television
Flat Panel Televisions Logo
140 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
