I have an error code on my TDS 300 "reset printer 12502". How can I fix it ?
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Posted on Aug 25, 2008
Joed911
  • 4338 Answers
SOURCE: error code 300. How fix
Do the EEPROM initialize reset;
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
  • 327 Answers
SOURCE: canon printer ip3300 error code 300
Hello,try to re-install the driver
Thanks
Posted on May 30, 2010
  • 790 Answers
SOURCE: oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Posted on Apr 28, 2014
roman_tolovi
  • 5 Answers
Upper paper roll drawer knife sensor failure and incomplete cut of the PRDU rolls.
Check the knife of the upper roll drawer.
May be the rubber tow, which make knife move, is broken. Or one of the sensors(left or right) is dirty. Or knofe motor is not working.
You can check motor movement by using service sds test 12-6-001.
Posted on Oct 24, 2017
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8507,i want A Solution
Turn off the printer, and let it cool for an hour. The problem will return, but you may have the ability to get some emergency plots out in the mean time. The error code has to do with a thermistor in the fuser section. These thermistors are made out of a delicate ceramic and are easily broken or cracked if installed incorrectly. I would recommend that you call an authorized Oce/Canon service representative unless you want to spend several hundred dollars on incorrect, or broken thermistors you may get via other official channels. Each Oce model may have a different rating of thermistor, so just putting any thermistor in most likely will not solve your problem and may cause others.
Mar 10, 2017 | OCE Office Equipment & Supplies
Oce TDS 300 Printer. Erore Prob. Hi I have a printer Oce TDS 300, I Get A new Erore code 8505,i want A Solution
The NTC 2 is probably shot. These are ceramic coated thermistors and extremely fragile. I would recommend calling an authorized Oce technician to get this replaced.
Oce tds error code 12502
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Tds 450 12502
Knife too fast to the right hand side. Open the drawer and see if you can pick out paper strips with long thin pair of tweezers. Careful not to damage the knife drive belt. or the sensors on either side.
Jan 12, 2014 | OCE Office Equipment & Supplies
I need a solution for konica 7145 error code 26-3
F26-3: TDS (Toner density sensor output abnormality) Abnormal output from TDS (Toner density sensor) TDS output ripple voltage failed to reach 0.5V
Possible that developer needs to be replaced or Toner is not supplying into the developer Unit.
Service Manual available to your model at: http://fixmfp.com/index.php?route=product/product&path=60&product_id=52
Sep 06, 2013 | Office Equipment & Supplies
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Error code 300. How fix
2. release RESUME
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
195 people viewed this question
k24674
jasbo
jasbo
